Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2003, 05:46 PM   #1
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
Default Cam "lope" question?
This may be an unanswerable question but here goes,
At what point does a cam begin to lope? I have read that, for vacuum puposes, it is not recommended to have more than .225 Intake at .050.
With that said and using a Hyd-Roller cam, would a .225 have any lope or just a smooth idle?
LD85 is offline   Reply With Quote
Old 04-09-2003, 07:22 PM   #2
vader86
CF Senior Member
vader86's Avatar
Default Re: Cam "lope" question? (ld85)
You can tune something around 225 int/exh to have a smooth idle, you could probably go a little bit bigger and not have very much lope at all.
vader86 is offline   Reply With Quote
Old 04-09-2003, 09:54 PM   #3
Vetterodder
CF Senior Member
Vetterodder's Avatar
With everything being equal, more duration will usually result in more lope but there's no majic line where lope will occur or not occur. Slightly more duration will give slightly more lope. A lot more duration will give a lot more lope. There are a lot of other factors like timing, fuel mixture, displacement, head port volume, etc., that will affect lope also. One engine may have a very noticeable lope with 220º and another may have none with 225º.
Lope is usually the result of lower intake velocities caused by longer duration and which prevent the fuel/air from mixing well or not keeping the fuel suspended in the air and also from exhaust gasses flowing into back into the combustion chamber. In the latter case, the lower intake air velocities offer less resistance to exhaust reversion and also, because both the intake and exhaust valves are open together for longer periods, there's more opportunity for this to occur.
Vetterodder is offline   Reply With Quote
Old 04-09-2003, 10:09 PM   #4
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Default Re: Cam "lope" question? (Vetterodder)
Quote:
...also, because both the intake and exhaust valves are open together for longer periods...
This, is of course, is "overlap". Overlap is the main contributor, to a lopy idle and a soggy low end. Overlap increases as duration increases. HOWEVER, for a given amount of duration, the overlap is decreased by increasing the amount of lobe separation.
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 04-10-2003, 12:05 AM   #5
NASCAR314
CF Senior Member
NASCAR314's Avatar
Default Re: Cam "lope" question? (CFI-EFI)
:confused: So by decreasing the lobe seperation you can actually "induce" lope into an engine?
In some cases, a "lope" is a desired property. In a cruising type car, not an all out race car and not a daily driver. (Street Rods for example :thumbs: )
Or, can you alter cam timing enough with a mild cam to "induce" a lope at idle?
Thanks,
Tom
NASCAR314 is offline   Reply With Quote
Old 04-10-2003, 12:15 AM   #6
L79vette
CF Senior Member
L79vette's Avatar
Default Re: Cam "lope" question? (NASCAR314)
Yup! Some people buy cams with short duration and very tight lobe separation like 106 or 104, so they get that lopey sound without killing their low end performance too much. I would never personally choose a cam for its sound. If you're gonna build the motor to sound fast, build it to be fast!
You can't induce a lope by advancing or retarding a cam. It has to have the valve overlap ground into it. You could slightly increase overlap by increasing the rocker ratio, but it would only make a very small difference.
[Modified by L79vette, 4:21 AM 4/10/2003]
L79vette is offline   Reply With Quote
Old 04-10-2003, 09:29 PM   #7
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
In am effort to make a "healthy" cam more streetable, copious amounts of spark advance, can help. If you want it to sound "nasty" try retarding the timing. It won't run like it should, but it will sound mean. Personally, I'd rather sound stock and run otherwise, than the opposite. Either way, good luck, and...
RACE ON!!!
Reload this Page Cam "lope" question?
Tags
106, cam, lope, make, retarding, timing, tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Z06 Cam Specs vs 99 C5 Cam Specs... question>> SilverC5Vert C5 Tech 30 03-23-2004 02:06 PM
MTI Stealth Cam Idle Problems X_03_Cobra_guy C5 Tech 32 11-11-2003 04:25 PM
Life with a Heads/Cam Car Question Redmenace C5 Tech 12 08-13-2003 06:18 PM
cam for LT1? dyno #s? sothpaw2 C4 Tech/Performance 17 02-14-2003 11:13 AM
383/396 Stroker driveability question 365ZUM C4 Tech/Performance 42 02-08-2002 04:02 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
