Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2003, 12:21 AM   #1
toy350
CF Senior Member
Default What is the best way to check air/fuel ratio
I am running a high compression motor (13:1)
and want to make sure the air/fuel ratio and timing are set properly to avoid detonation, but maximize performance. What is the best technique to check for the proper ratio and timing.
My previous motor took chunks out of 3 pistons which I presume was from detonation. The car is so loud it is extremely hard to hear any detonation. I don't want the same outcome on my new motor.
Thanks.
toy350 is offline   Reply With Quote
Old 04-09-2003, 03:50 AM   #2
88-406
CF Senior Member
St. Jude Donor '05
88-406's Avatar
Send a message via AIM to 88-406 Send a message via Yahoo to 88-406
Default Re: What is the best way to check air/fuel ratio (toy350)
Most dyno shops will monitor the AFR with a wide band o2 during a pull for a small extra fee. Or you can invest in your own wbo2 onboard system for $350-400.
I like the on board method because it shows me in real time how my tune is holding up.
KM
88-406 is offline   Reply With Quote
Reload this Page What is the best way to check air/fuel ratio
Tags
air, check, fuel, garage, monitor, ratio
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 72 11-21-2011 03:50 PM
Should we drop the C6 bit? Tom73 C6 Corvette General Discussion 26 11-04-2003 10:16 AM
What would be your Ultimate Dream Small Block? John Dirks C3 Tech/Performance 23 09-10-2001 11:00 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
