04-08-2003, 10:41 AM
CF Senior Member
Brazing an oil return fitting to pan
I need to BRAZE a fitting onto my oil pan. Have MIG welded for years but NEVER brazed. Any advice appreciated. TIA !!!
04-08-2003, 05:57 PM
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
Re: Brazing an oil return fitting to pan (GRX)
brazing is using a brass rod and flux but the big thing is to make sure that the surfaces are clean and oil free. if the part is steel i would TIG weld it. :chevy
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
