Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-07-2003, 01:23 PM   #1
GRX
CF Senior Member
GRX's Avatar
Default Locktite on Aluminum head exhaust studs
Which is better on aluminum head exhaust studs? Blue or Red???
GRX is offline   Reply With Quote
Old 04-07-2003, 03:12 PM   #2
Monty
CF Senior Member
Monty's Avatar
Default Re: Locktite on Aluminum head exhaust studs (GRX)
I use ARP stainless header studs in my aluminum heads, but I don't use Loctite, but rather an appropriate antiseize. Studs should not be torqued into the reciever, just hand tight. The antiseize will help prevent the galvanic corrosion which occurs between dissimilar metals, especially aluminum and steel/stainless.
Monty is offline   Reply With Quote
Old 04-07-2003, 08:20 PM   #3
Daffy2
CF Senior Member
Daffy2's Avatar
Monty is right, use anti-sieze. Use a small amount on your plug threads too. Niether loctite would survive exhaust area heat anyway, but the heat degenerated loctite could interfere with removal.
Daffy 2
Daffy2 is offline   Reply With Quote
Old 04-08-2003, 07:45 AM   #4
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Default Re: Locktite on Aluminum head exhaust studs (Monty)
:iagree: A good nickel-based anti-seize :thumbs:
Plus Normally, Loctite red requires HEAT for removal if installed correctly the first time.Blue is for fasteners under 3/4 "
Have a read fest :cheers: http://<a href="http://www.loctite.c...ebook.html</a>
http://www.loctite.com/pdf/lt3355c_MRO_Anti-Seize.pdf
Allthrottleandsomebottle is offline   Reply With Quote
Old 04-10-2003, 10:15 AM   #5
GRX
CF Senior Member
GRX's Avatar
Default Re: Locktite on Aluminum head exhaust studs (ALLTHROTTLE&NOBOTTLE)
Thank you!
Reload this Page Locktite on Aluminum head exhaust studs
Tags
aluminum, arp, blocks, engine, exaust, exhaust, head, header, heads, locktite, loctite, removal, removalaluminum, stud, studs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is it safe to use locktite on header bolts with aluminum heads? GrandSportC3 C3 Tech/Performance 37 05-07-2005 01:37 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
