Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-04-2003, 03:27 AM   #1
69 N.O.X. RATT
CF Senior Member
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default .025 ring gap enough for a 200 shot ?
I have the horsepower bug bad, I do not even have the motor together and I am already planning on a second NOS system :nonod: Any way the plan now is to run a 100 shot out of my Fogger and then hit another 100 in the next gear up (from a plate system). When I put the motor together we file fit the top ring at .025 total. Since the heads are off I comfimned this by sticking a .025 wire down between the ring gap and it barely fit.
I have all the right stuff to run a much bigger shot than this (forged everything, etc) I am ok with .025 total for the ring gap for a 200 shot ?
At least I have toned down the idea of running a total of 250 worth of NOS.
69 N.O.X. RATT is offline   Reply With Quote
Old 04-04-2003, 08:43 AM   #2
norvalwilhelm
CF Senior Member
norvalwilhelm's Avatar
Default Re: .025 ring gap enough for a 200 shot ? (69 N.O.X. RATT)
I'm running .023 on both the upper and second ring on my blower motor as per instructions. I assume I haven't had any problems. So far the motor runs great.
norvalwilhelm is offline   Reply With Quote
Old 04-04-2003, 12:02 PM   #3
69 N.O.X. RATT
CF Senior Member
Default Re: .025 ring gap enough for a 200 shot ? (norvalwilhelm)
Norval, I would assume I will OK. Do you remeber the gap you used when you sprayed the motor a lot.
Old 04-04-2003, 07:10 PM   #4
norvalwilhelm
CF Senior Member
I would say that you are OK. I don't remember my old nitrous motors ring gap. I bought a ring gap grinder that I don't use very often. You don't want the gap too big, nor do you want the rings to but up and seize. I feel your .025 is plenty.
Reload this Page .025 ring gap enough for a 200 shot ?
Tags
025, 200, gap, gaps, ring, shot
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
