Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Engine Mods
Outrageous Builds, High-Horsepower Modifications, strokers, and big cams for the Corvette Sponsored by
CARiD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-01-2003, 01:47 PM   #1
scorp508
CF Senior Member
scorp508's Avatar
Default BBC casting 14015445, tall deck?
A few of these 14015445 blocks are on eBay. It appears that they came out of trucks. Anybody have any solid proof as to if they are a tall deck or not? I'm waiting for one of the sellers to get back to me right now.
Mortec.com only says...
14015445...454.......78-90...2 or 4 bolt
Thanks. :seeya
scorp508 is offline   Reply With Quote
Old 04-01-2003, 01:59 PM   #2
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
Default Re: BBC casting 14015445, tall deck? (scorp508)
there were never any 454 tall blocks,only 366 and 427. 14015445 are out of motorhomes and pu trucks :chevy
clem zahrobsky is offline   Reply With Quote
Old 04-01-2003, 06:12 PM   #3
scorp508
CF Senior Member
scorp508's Avatar
Default Re: BBC casting 14015445, tall deck? (clem zahrobsky)
Thanks, the seller replied confirming it was a 9.800 block.
Old 04-01-2003, 08:58 PM   #4
danno85
CF Senior Member
Another quick way you can tell is that on a std deck block, the upper water
pump bolt hole is right near the deck surface, probably only an 1/8 inch away, and on the tall deck block it's a good 1/2"+ away from the deck.
Dan
danno85 is offline   Reply With Quote
Old 04-01-2003, 09:16 PM   #5
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
I am not disputing the casting no. info, but there WERE tall deck Gen IV 454's. Care to buy some pistons? Buyers, beware! Good tip, Danno85.
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 04-02-2003, 08:51 PM   #6
bence13_33
CF Senior Member
bence13_33's Avatar
Scorp:
I agree with Clem, there weren't any tall deck 454 big blocks until the Gen V motor. The only motors that were tall decks were 366s & 427s.
bence13_33 is offline   Reply With Quote
Old 04-02-2003, 09:21 PM   #7
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Default Re: BBC casting 14015445, tall deck? (bence13_33)
Would anyone have an alternate application for Perfect Circle piston part number, 224-2782? It is a 4.25" bore with a 2.040 compression distance. It is a 4 ring piston and PC lists it for 1970's, 454, medium duty trucks. With a 2.00" (454 = 4.00" stroke) crank throw and a 6.135" rod, that adds up awfully close (10.175") to a 10.20" block height. I personally, have not encountered one of these engines, and the books COULD be in error, but that is my authority. May be not, but it wouldn't hurt to check before you buy.
RACE ON!!!
Old 04-04-2003, 01:54 AM   #8
sinistervette
CF Senior Member
sinistervette's Avatar
Default Re: BBC casting 14015445, tall deck? (CFI-EFI)
RACE ON!!!
The pistons you listed were origionally made available for guys wanting to bore the 427TD blocks to 4.250 bore. They are also now used in the aftermarket TD blocks with the 427/454(4" stroke) cranks. The 454 was not made with a tall deck design. As stated above, the visual way to spot a tall deck is the distance from the top water pump bolt hole to the deck surface. :cheers:
Hey Scorp......you thinking about a BBB? That is a big block bannana! :cool:
sinistervette is offline   Reply With Quote
Old 04-04-2003, 01:57 AM   #9
sinistervette
CF Senior Member
I forgot this.....14015445= 454, 1975-1987 truck, light duty(as per GM). :cheers:
Old 04-04-2003, 09:43 PM   #10
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Default Re: BBC casting 14015445, tall deck? (sinistervette)
Quote:
The pistons you listed were origionally made available for guys wanting to bore the (1) 427TD blocks to 4.250 bore. They are also now used in the aftermarket TD blocks with the (2) 427/454(4" stroke) cranks.
Just a little mis-information, here.
(1) 427's and 454's share a 4.25" bore. GM didn't increase the 427 bore to attain 454 ci.
(2) 427's have a 3.76" stroke. 454's have a 4.00" stroke. GM STROKED the 427 to get the 454.
All MarkIV engines (366, 396, 402, 427, and 454) share a common, 6.135" length rod. All those engines, EXCEPT the 454 had the 3.76" stroke. Consequentally, piston compression distance only changed with block deck height, until the 4.00" stroke 454 was introduced.
I hope this helps clarify things for the BB students, following this. Good luck, all, and...
RACE ON!!!
Old 04-04-2003, 11:39 PM   #11
sinistervette
CF Senior Member
OOOPS. Talk about a brain fart! :rolleyes: I knew they shared bore(427/454) but not sure why I typed that! I've used the 396 crank in a 454 block before to make a 427 clone. Must be too many :cheers: .
Old 04-05-2003, 03:11 PM   #12
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Quote:
OOOPS.
I think we've all done that. I know *I* have.
Dimensionally, the 366, 396, and 427, cranks are the same, tall or short deck block. Likewise, the 427 and 454 blocks, in either the tall or short deck verson.
Because of the sameness of the 427 and 454 blocks, one way to differentiate between 427 and 454, is to feel the inside of the harmonic damper (balancer). Feel for a constant ID of the outer portion. A constant ID indicates a 427 (internal balance), a "bump" in the ID is an external balance weight. The 454's are externally balanced, like the sbc 400. all other Mark IV's are internally balanced like the sbc 350. Same flywheel/flexplate difference, too.
RACE ON!!!
Reload this Page BBC casting 14015445, tall deck?
Tags
14015445, 366, 427, bbc, casting, compression, deck, engine, hole, horse, mark, piston, power, starter, tall
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
