Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-28-2003, 12:27 AM   #1
WashingtonRacer
CF Senior Member
Send a message via AIM to WashingtonRacer
Default TPI or Victor efi?
Okay I was originally working on converting a torquer manifold to EFI. I decided to stop just cause I didn't like the shape of the runners at the exit.
I just bought a Billet 1000cfm Accel throttle body, And was thinking of picking up a victor EFI manifold which is only 250 bucks or so. Accel makes one too along with Holley. But on the other side of the scope. I was thinking about the TPI units. I know stock they run out of breath around 5k rpm. But if high flow runners and baseplate was installed, along with a 1000 cfm throttle body. Everything else is already there, Perhaps just larger Fuel rails, which I already have. Could/ would the TPI system be a possible idea? hoping to see around 1045hp at 7k
[Modified by WashingtonRacer, 4:34 AM 1/28/2003]
WashingtonRacer is offline   Reply With Quote
Old 01-28-2003, 08:32 AM   #2
No Go
CF Senior Member
Default Re: TPI or Victor efi? (WashingtonRacer)
1045 HP? Is that a typo?
TPI isn't going to cut it for a 7000 rpm engine...
Go with the single plan setup-Holley/Victor/etc...
No Go is offline   Reply With Quote
Old 01-28-2003, 01:20 PM   #3
GregP
CF Senior Member
GregP's Avatar
For that kind of power (airflow) I'd look at the BDS tunnel ram based systems.
-Greg
GregP is offline   Reply With Quote
Old 01-28-2003, 01:31 PM   #4
Monty
CF Senior Member
Monty's Avatar
Are you familiar with Doug Hegge's 1000+hp TT 375? http://www.jdhcon.com/vette , he's near you up in the Seattle area I believe. He recently switched from a EFI converted Victor JR to a Miniram II and he said he didn't lose ny pwoer or torque across the rpm range. He had to machine the fuel rails to increase flow, but there doesn't seem to be any difference on performance. By the time you add up the cost of an aftermarket TPI base and larger runners, the MRII might not be a bad option and it will obviously support flow up to and past 7000rpm.
[Modified by Monty, 11:33 AM 1/28/2003]
Monty is offline   Reply With Quote
Old 01-29-2003, 04:16 AM   #5
WashingtonRacer
CF Senior Member
Default Re: TPI or Victor efi? (Monty)
I would like to just stick with the Victor style manifold. I am actually waiting on the throttle body still, "should be here by friday." I will do comparative test fit. As long as it fits under the hood then I am good to go. I believe the victor EFI manifold is 4.5 inches total height. I believe the total height of the my current torquer manifold is a whopping 3.75 or so. now my old setup used an inch spacer to allow the hat to sit over the carb. All I can hope for is a drop in the overall height of the throttle body compared to the Holley.
Old 02-03-2003, 01:43 PM   #6
6SSPD
CF Senior Member
Definitely go with the ACCELL/LPE PRO-RAM, here is mine with a modified PLENUM box I made, plus an Edelbrock Spread bore-to-Dominator 1" spacer, which dramatically increases the plenum area for high RPM usage. The stock T.B. was just used to mock-up purposes. This isn't for a C-4 application, but you get the picture. HTH's
:chevy :chevy
6SSPD is offline   Reply With Quote
Reload this Page TPI or Victor efi?
Tags
efi, tpi
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any N/A Lt-1's making 500 rwhp? Kehrer923 C4 Tech/Performance 75 07-26-2005 01:54 AM
single plane conversion q2blaster C4 Tech/Performance 20 07-11-2005 05:29 PM
modify the STEALTH RAM INTAKE to fit the c-4 vettes grumpyvette C4 Tech/Performance 38 08-12-2004 01:59 PM
Single Plane EFI manifold conversion for C4 Vettes- Prototype Finished! jburnett C4 Tech/Performance 104 11-14-2003 11:58 AM
SuperRam vs MiniRam vs StealthRam vs EFI'd Victor Jr on a 400+ CID motor vette_tweak C4 Tech/Performance 101 07-18-2003 08:11 PM
Any L98 guys have a mix of 1.6rr's and 1.5rr's or info? pablocruise C4 Tech/Performance 16 03-04-2002 06:30 PM
Carb or fuel injection? vettegirl C3 Tech/Performance 9 09-28-2001 11:10 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
