Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-27-2003, 02:31 AM   #1
88-406
CF Senior Member
St. Jude Donor '05
88-406's Avatar
Send a message via AIM to 88-406 Send a message via Yahoo to 88-406
Default Re: Aluminum flywheel question
Anyone ever try one? How are they on the street? Where the gains noticable? Is it doable? My setup is a 383,3.73 rear gear, 2.68 first gear ratio.
KM
88-406 is offline   Reply With Quote
Old 01-27-2003, 11:52 AM   #2
L79vette
CF Senior Member
L79vette's Avatar
Default Re: Aluminum flywheel question (88-406)
Not aluminum, but a lightweight nodular iron wheel. The weight is all the matters as far as the effect goes. Made a very noticeable difference in first gear especially. Not hard at all to drive. Just use slightly more RPM for normal starts. Of course you can go crazy and buy very low weight circle track pieces, which would be very difficult to drive with. The stock 30lb. wheel is designed for extreme ease of getting the car started, at the expense of acceleration.
Here's a link to some physics analysis of the situation:
http://www.pumaracing.co.uk/flywheel.htm (seems to be down right now)
Drag racers sometimes use extra heavy wheels, to help pull the car out of the hole without bogging. But, they are using extra sticky tires that won't spin, and are willing to sacrifice the extra energy needed to spin the wheel back up after the launch pulls the RPM down.
L79vette is offline   Reply With Quote
Reload this Page Re: Aluminum flywheel question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Aluminum flywheel worth it for Autocross? Drako Autocrossing & Roadracing 29 07-01-2004 02:23 PM
Aluminum Flywheels: Yay or Nay??? OliverM5 C5 Tech 33 11-30-2003 06:27 PM
Fidanza flywheel question... ncsugreywolf C4 Tech/Performance 13 10-12-2003 11:55 PM
Is there any benifit to an aluminum Flywheel vs steel? BeachinVette C3 Tech/Performance 13 11-13-2002 07:00 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
