Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-24-2003, 02:45 PM   #1
350camaro
CF Member
Default 68cc chamber AFR heads and domed pistons
I am trying to find out if any one else is using domed pistons with the 68cc chamber AFR heads, and what pistons they used and if the pistons or combustion chamber needed to be modified.
When I built mine I ended up using the Keith Black hyperutectic KB-119 with a 0.1 dome 1970 LT1 replacement piston. I had to remove a slight amount of material from the combustion chamber on the intake side, I am sure it was less than 0.5cc's.
350camaro is offline   Reply With Quote
Old 01-24-2003, 03:09 PM   #2
71roadster
CF Senior Member
71roadster's Avatar
Default Re: 68cc chamber AFR heads and domed pistons (350camaro)
I was going to use the kb122 with a 7cc dish and the 68 cc head, but that made the compression too low. So I went with the kb123 with a 3.25 cc dome and the 74cc head. I had the machinist machine the dome down to get a total of 10.3:1 or so total compression. It was cheaper to machine the pistons than it is to mill the heads. I am not quite sure what the exact displacement of the pistons is now, but the dome is only about 1/16 of an inch. I think that is better as a larger dome tends to impede flame travel. I would think a dome piston and a 68cc chamber would raise your compression way hi.
Chris
71roadster is offline   Reply With Quote
Old 01-24-2003, 03:37 PM   #3
350camaro
CF Member
Default Re: 68cc chamber AFR heads and domed pistons (71roadster)
The KB-119 that is in the motor is only 0.1 inches high, my compression ratio with the 0.015 deck height, the fel-pro 1010 head gasket and 68cc chamber comes out to 10.2:1. The only thing I don't like about the AFR 195's is in order to get a decent compression rato on a 350 you have to use a piston with a small dome or mill the heads. I did not want to mill the heads because then if I decide to try a different intake I would have to get the new intake milled too.
Reload this Page 68cc chamber AFR heads and domed pistons
Tags
1010, 195, 350, 68, 68cc, afr, cc, chamber, dome, domed, felpro, gasket, heads, piston, pistons
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
