Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-23-2003, 12:03 PM   #1
johndezman
CF Senior Member
Default 1.7 ford rockers - anyone tried them?
looking through a couple equipment catalogs i've noticed 1.7 ration rockers for small fords.
has anyone tried them on a small chevy? guess the push rod slot would have to be opened up a bit!
johndezman is offline   Reply With Quote
Old 01-23-2003, 01:29 PM   #2
Lt1er
CF Senior Member
Lt1er's Avatar
Default Re: 1.7 ford rockers - anyone tried them? (johndezman)
Crower has very big ratio roller rockers for Chevy's. The pushrod head hole size is just one of the many areas you would have to cover if you went with rockers like that.
Lt1er is offline   Reply With Quote
Old 01-23-2003, 05:19 PM   #3
johndezman
CF Senior Member
Default Re: 1.7 ford rockers - anyone tried them? (Lt1er)
what else do you know of that would need to be checked/modified?
Old 01-23-2003, 06:51 PM   #4
gkull
CF Senior Member
gkull's Avatar
Your first consideration is: Can the valves spring handle the extra ratio caused lift? Do your spring retainers crush the valve seals? Are your screw in studs long enough to allow for enough lash adjustment with the longer pushrods required to center the roller rockers on the tip of the valve stems?
Then in extreem cases. Do you have to worry about valve to piston clearance.
I have heard of 1.9 ratio rockers but I have never seen one.
gkull is offline   Reply With Quote
Reload this Page 1.7 ford rockers - anyone tried them?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
AutoCross - What Air Pressure for Non-Runflats? RacerChris C5 Tech 9 07-07-2003 03:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
