Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-21-2003, 12:49 PM   #1
Dracula383
CF Senior Member
Default Need help with DFI car stalls every now and then...
Hey does anyone know what I need to configure in the calmap program(version 6.32) to keep the car from stalling at certain times when I let off the gas abruptly. I assume its the stall saver but I don't understand what the different values on the graphs need to be to get it right. Also if I abruptly give it a lot of throttle sometimes it hesitates and even backfires. Any info is appreciated. -James
I also posted this in the c4 scan and tune in case you have seen this twice.
Dracula383 is offline   Reply With Quote
Old 01-21-2003, 02:05 PM   #2
Monty
CF Senior Member
Monty's Avatar
Default Re: Need help with DFI car stalls every now and then... (Dracula383)
I used to have that system. I would work with the Stall Saver as you mentioned. It steps out the IAC motor to prevent the stalls you are experiencing.
Is the backfire you're experiencing though the exhaust, or through the intake?
Monty is offline   Reply With Quote
Old 01-21-2003, 10:26 PM   #3
WashingtonRacer
CF Senior Member
Send a message via AIM to WashingtonRacer
Default Re: Need help with DFI car stalls every now and then... (Monty)
whats the difference between the Gen 7 and Gen 6? does the gen 6 give you the same performance possibilitys as gen 7? I am okay with the does based system, besides I don't plan enjoying my vett with a lap top in the passenger seat. Got better things to go there.
WashingtonRacer is offline   Reply With Quote
Old 01-22-2003, 12:03 AM   #4
Monty
CF Senior Member
Monty's Avatar
Default Re: Need help with DFI car stalls every now and then... (WashingtonRacer)
The 7 has Window's based graphical software, much easier to use than the old DOS 6.xx. The new hardware is universal for the most part, the 6.xx stuff had to be sent back to Accel to upgrade, plus they added more options, i.e. Wide-band O2, etc.
Old 01-22-2003, 01:13 AM   #5
Dracula383
CF Senior Member
Hey Monty,
the backfire is coming from the intake actually and only does it once in a great while when going from a cruising idle to a stab at the gas. Also when doing this is hesitates. Not crisp response at all.
Old 01-22-2003, 12:59 PM   #6
Monty
CF Senior Member
Monty's Avatar
Sounds like it's lean to me then. Drive around and see where the engine is operating in the Base Fuel Map when this happens and try adding a little more pulsewidth in that area. If that doesn't solve it, try increasing the TPS Enrichment.
Reload this Page Need help with DFI car stalls every now and then...
Tags
car, dfi
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
