Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-20-2003, 01:32 PM   #1
MoMo
CF Senior Member
MoMo's Avatar
Default Remember my oil pressure problem?
I don't know what happened to my original post, but it's gone. Anyway, I posted about a low oil pressure problem on my new 427 big block that got worse when the engine warmed up. The general concensus was that I probably had some bad bearing clearance, or clogged oil filter, and a few other suggestions.
Well, none of the above. I found the problem. I pulled the pan and started looking around. What I found, I couldn't believe I didn't catch on the engine stand!
The oil pump wasn't seated fully on the mating surface of the rear main cap. It was held almost an eighth of an inch off on the back side (closest to the flywheel) because the body of the pump was interfering with the one of the nuts on the ARP studs holding the mains.
I also replaced the pump because it was sticking. Rather than risk putting a marginal pump back in, a new high volume Melling is cheap insurance.
But what I did was to take off that nut and grind it down to about the thickness of a bolt head, and then the pump cleared fine.
It is now fully seated on the mating flange.
This is something to watch out for if you guys build a big block Chevy with an upgrade to ARP studs rather than bolts on the mains.
CHECK THE OIL PUMP FOR CLEARANCE!!!
:eek:
MoMo is offline   Reply With Quote
Old 01-20-2003, 01:43 PM   #2
427Hotrod
CF Senior Member
427Hotrod's Avatar
Default Re: Remember my oil pressure problem? (MoMo)
Good news.....
Did you pull any bearings and check them out? Better to replace them now if any look marginal after running with low pressure.
Glad you found it...
JIM
427Hotrod is offline   Reply With Quote
Old 01-20-2003, 11:40 PM   #3
MoMo
CF Senior Member
MoMo's Avatar
Default Re: Remember my oil pressure problem? (427Hotrod)
The bearings looked fine. In fact, the engine looks great. The oil is perfectly clean with no metal fragments at all.
I fired it up and let it get warm. 42 psi at idle cold, and a full 30 psi with the engine warmed up. Rev it and the gauge goes way north.
So it's fixed. What a huge load off my mind.
Back to enjoying my Vette.
Old 01-21-2003, 03:03 PM   #4
71roadster
CF Senior Member
71roadster's Avatar
Same thing with a small block with arp studs. Even tho one stud is shorter than the other, it is still too tall that it interferes with the oil pump. Can't beleive ARP hasn't corrected this.
Chris
71roadster is offline   Reply With Quote
Old 01-21-2003, 05:09 PM   #5
bence13_33
CF Senior Member
bence13_33's Avatar
Momo:
I ran into the same problem with my 454. One of the ARP main stud nuts was keeping my Melling high volume oil pump from mating up flush. It took me a couple of trips over to the dremel before I correctly ground enough metal off of the oil pump.
I'm glad that was your only problem.
bence13_33 is offline   Reply With Quote
Old 01-23-2003, 05:12 PM   #6
Clink69
CF Senior Member
Clink69's Avatar
Default Re: Remember my oil pressure problem? (bence13_33)
Shane ,
When are you going to update you Sig to show your new HP in the 468...? :D
Chris :flag
Clink69 is offline   Reply With Quote
Reload this Page Remember my oil pressure problem?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1981-82 Owners. Need Pic of Oil Pressure Gauge Install... paul 74 C3 Tech/Performance 14 01-04-2003 04:47 PM
HELP!!!! OIL PRESSURE PROBLEM.. Radio Joe C4 Tech/Performance 9 07-06-2002 10:50 PM
oil pressure issue again GlockLT4 C4 Tech/Performance 48 06-06-2002 07:54 PM
100k+ guys.. what is your oil pressure at idle when the oil gets around 200? GlockLT4 C4 Tech/Performance 29 09-21-2001 08:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
