Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-19-2003, 07:33 PM   #1
Hank
CF Senior Member
Default Mechanical roller lifters on a hydraulic roller cam!
As many of you know I'm working on my 502 66 roadster this winter, upgrading the heads, cam, and exhaust. Today I got the cam out and ...
The cam is a "6543" (stamped on one end) roller -- so it's the 502/502 standard GM Gen VI hydraulic roller cam (GM #1236 6543).
The lifters on the cam, on the other hand, are solid rollers -- they look a whole lot like the solid lifters on the comp cams site but don't have any markers. The lifters look good. The engine has comp cams magnum pushrods and comp cams pro magnum roller rockers.
When I spoke to the prior owner (who built the engine) he said he had swapped in mech roller cam and swapped it back out but he swore up and down that the car had hydraulic roller lifters when he sold it. Oops.
NO WONDER I HAD SO MUCH TROUBLE SETTING THE VALVE LASH! Assuming I had hydraulic rollers (as he had said), I tried the "zero lash plus 1/4 turn" method and (duh) got no compression. So I went to 0.020" and it ran great.
So for those of you who were wondering -- yes you can run a hydraulic roller cam with solid roller lifters. Or, I was very lucky. But the thing ran great for 3+ years of street use (summers only, probably 4-5k miles).
I'm researching cam options now -- thinking a big hydraulic roller such as the crane 139741, 234/242 duration at 0.050, .610-.632" lift.
Gerry
Hank is offline   Reply With Quote
Old 01-19-2003, 08:24 PM   #2
ED DINAPOLI
CF Senior Member
ED DINAPOLI's Avatar
Default Re: Mechanical roller lifters on a hydraulic roller cam! (Hank)
When purchasing my SB roller cam from Comp Cams, they told me that the cam could be used with solid or hydraulic rollers.
Ed
[Modified by ED DINAPOLI, 7:26 PM 1/19/2003]
ED DINAPOLI is offline   Reply With Quote
Old 01-19-2003, 09:56 PM   #3
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
i would set the lash at .003/.005 hot and you will be fine.
clem zahrobsky is offline   Reply With Quote
Old 01-20-2003, 01:58 PM   #4
427Hotrod
CF Senior Member
427Hotrod's Avatar
The reason it worked pretty well, is that you ahve a very mild hyd roller there. When you get into more aggressive cams, things change.
A solid roller or flat tappet has "clearance ramps" built into the first and last part of the lobe to gradually take up the slack and easily let it close. As the cam becomes more aggressive, these ramps become more important to keep the valvetrain from beating itself to death.
You can usually get by with hyd's on a flat tappet, but it doesn't work as well as it could. The lift starts earlier than it would with solid lifters and acts "bigger". If it was a cam designed for hyd's they would take advantage of not needing to take up the clearance and make the cam even more aggressive in the first and last few degrees off opening and closing to increase performance.
Of course right up to a point where the hyd's float or pump up. There are many race guys running solid cams with hyd. lifters and setting them as solids to meet rules requirements. Of course, they tear them down and replace parts a lot too.
Clem's way of setting them at .003 or so will work, but still doesn't address the performance potential loss of having the right cam combo. I wouldn't select a new Hyd, roller cam and plan to run it that way.
I'd take this as a perfect opportunity to put in a good street roller SOLID cam and be happy about it!!
JIM
427Hotrod is online now   Reply With Quote
Reload this Page Mechanical roller lifters on a hydraulic roller cam!
Tags
12366543, 6543, cam, gm, hydralic, hydraulic, lifters, mechanical, roller
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rebuilding a '66 327/350hp would you do roller rockers? sams'66 C1 & C2 Corvettes 13 09-12-2003 01:07 AM
Mechanical vs. Hydraulic, Roller vs. Flat OatBoy Engine Mods 9 06-25-2003 02:05 AM
1985 Roller conversion HoustonBob C4 Tech/Performance 17 03-21-2003 03:59 AM
Roller lifters... worth the money? Ryan77 C3 Tech/Performance 11 03-18-2003 11:39 PM
AFR Hydraulic Roller Rev Kits -- anyone using these? Togo C4 Tech/Performance 34 11-23-2002 10:28 AM
Roller cam experts,chime in... BB wowbagger C3 Tech/Performance 14 10-15-2002 02:35 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
