Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-19-2003, 07:07 PM   #1
flyersfan1088
CF Senior Member
flyersfan1088's Avatar
Location: What did the 5 fingers say to the face? SLAP!!
Default Just rebuilt motor. Now have terrible mileage.
I just had the motor in my '86 rebuilt. I had the stock iron heads ported and a bigger cam put in (224 dur @.050 .495 lift) I am now averaging 12 mpg. I am 99% sure that the cam was installed a couple of degrees retarded, which is going to be fixed. Can running the cam retarded effect fuel mileage this much? Or do engines get worse mileage during break in?
flyersfan1088 is offline   Reply With Quote
Old 01-19-2003, 08:34 PM   #2
QuickVet
CF Senior Member
QuickVet's Avatar
Default Re: Just rebuilt motor. Now have terrible mileage. (flyersfan1088)
yes, timing can affect milage. Fix that first and then see if it gets better. Welcome to the world of more HP and less milage :lol:
QuickVet is offline   Reply With Quote
Old 01-20-2003, 12:50 AM   #3
Vetterodder
CF Senior Member
Vetterodder's Avatar
While 2º retarded cam timing might result in lower fuel economy (in some cases it might result in higher fuel economy), the difference wouldn't be that dramatic either way. Lower mileage during breakin isn't unusual due to ring seating issues but, assuming that we're talking about a TPI engine, only 12 mpg is way beyond what would be expected. I suspect two issues are involved in your case. One is that you're enjoying the hell out of the new engine and you've lost control of your right foot :). The other is that your computer hasn't been reprogrammed for the bigger cam and has your injectors working overtime.
Vetterodder is offline   Reply With Quote
Old 01-20-2003, 12:29 PM   #4
flyersfan1088
CF Senior Member
Default Re: Just rebuilt motor. Now have terrible mileage. (Vetterodder)
Well, it's probably a little of both. I'm still learning about custom PROMS. I hadn't thought about reprogramming to regain economy. Thanks for the tip :)
Reload this Page Just rebuilt motor. Now have terrible mileage.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Throttle body bypass detto C4 Tech/Performance 17 09-27-2002 12:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
