Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2003, 05:29 PM   #1
Jack71
CF Senior Member
Jack71's Avatar
Send a message via AIM to Jack71
Default Planning 406, rookie questions...
I've read a ton of good info out here on 400 blocks. This is a great place to learn.
So, with a 400, I'd like to put longer rods in there. Is any additional machine work necessary to use 5.7 or 6 inch rods?
I'll probably just buy a complete rotating assembly from SCAT or something.
Also, I'd like to use a hyd roller cam. Besides the purchase cost of the cam and lifters, what other upgrades or machine work may be necessary?
Thanks in advance for any help.
--Jack
Jack71 is offline   Reply With Quote
Old 01-19-2003, 09:28 AM   #2
1979toy
CF Senior Member
1979toy's Avatar
Default Re: Planning 406, rookie questions... (74jack)
Longer rods will give you less distance from the piston pin to the top of the piston. That is also the area where the piston rings live. For a street motor thicker rings are better. With 6 inch rods the piston pin is under the lower rings.
Longer rods will also give you more clearance issues with the camshaft. You may not hit with a 5.7 rod and a street cam but any more will require grinding. That is all dependant on what cam, rods and rod bolts you use.
If you are going to use a roller cam you will need to use valve springs designed for that. They are larger diameter than regular springs so you will have to have the valve spring seats machined, even on most aftermarket heads.
1979toy is offline   Reply With Quote
Old 01-19-2003, 10:58 AM   #3
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
Default Re: Planning 406, rookie questions... (1979toy)
Good info here http://www.eecis.udel.edu/~dzug/92z28/406project.html
LD85 is online now   Reply With Quote
Old 01-21-2003, 11:33 AM   #4
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
Default Re: Planning 406, rookie questions... (ld85)
You can see my setup going together in the C4 tech section.
Corky is having great sucess with the setup at 11.10@124mph.
The rods are Lunati 5.7" and needed to be clearanced just a hair to clear the cam.
Corky had built quite a few engines and warned against longer rods that intersect the oil ring lands. He said you will eventually have oil burning problems. :cheers:
Go check out the buildup.
ski_dwn_it is offline   Reply With Quote
Reload this Page Planning 406, rookie questions...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
