Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-17-2003, 09:29 AM   #1
1979toy
CF Senior Member
1979toy's Avatar
Default Drill heads for 406
It's time to put the heads on my 406 project. The Performer RPM heads need to be drilled for the steam passages.
Can I do this at home on a drill press or do I need to take them to a machine shop?
Is laying the head gasket in place enough to tell where the heads need to be drilled?
1979toy is offline   Reply With Quote
Old 01-17-2003, 11:25 AM   #2
Twin_Turbo
CF Senior Member
Default Re: Drill heads for 406 (1979toy)
You can do it at home, the gasket is a good template for the location of the holes. Holes should be drilled at a 10 degree angle aiming towards the chamber and w/ a diamter of 3/16"
[Modified by Twin_Turbo, 9:26 AM 1/17/2003]
Twin_Turbo is offline   Reply With Quote
Old 01-18-2003, 11:58 PM   #3
Lionsden
CF Senior Member
Lionsden's Avatar
Send a message via ICQ to Lionsden
Drilling the heads for steam holes isn't hard if you have the correct drill size and angles. I don't know if Marck's instructions are for Edelbrock heads but they are quite a bit different than the AFR instructions. AFR has instructions on their site but I couldn't find instructions on Edelbrock's site.
Contact Edelbrock tech to be sure of the correct procedure. Then 'go for it'. Heck, if you wait untill the 7th Dave, Chance and I will fix you right up!! :D
Lionsden is offline   Reply With Quote
Old 01-19-2003, 09:00 AM   #4
1979toy
CF Senior Member
1979toy's Avatar
Default Re: Drill heads for 406 (Dan Plett)
Too late. David and I did a guess and go type of drill job.
Edelbrocks techenical web site is just like having a 9600 baud modem again! If you call them they ask if you've got an internet connection and tell you to go there. I'm not sure I would have belived any answer that I got from them after that.
Old 01-19-2003, 05:48 PM   #5
Twin_Turbo
CF Senior Member
holy smokes, the tech database is indeed insanely slow :eek:
Old 01-21-2003, 11:28 AM   #6
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
Default Re: Drill heads for 406 (Twin_Turbo)
When Corky and I put together our motors we did not drill for the steam holes. Corky did his engine before mine and has not had any overheating problems. However on other engines he did, he drilled the hole and had continual head gasket problems. He epoxied the steam hole shut and the head gasket problem went away. So we did not bother to drill mine out. I think a lot of the heating problems people had in the past with the 400 blocks were contributed to inadequate radiators (the old style). :cheers:
ski_dwn_it is offline   Reply With Quote
Reload this Page Drill heads for 406
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Questions for those with 406's 79VetteMike C3 Tech/Performance 16 01-19-2005 03:06 AM
Looking for a crate motor 383 garandfan C3 Tech/Performance 11 09-22-2003 10:59 PM
sb 400 heads vette406 C3 Tech/Performance 16 08-15-2003 10:48 PM
L98 car going for a 406...what i need? SUPERNINJAB0Y C4 Tech/Performance 13 08-02-2003 12:11 AM
406 vs. 355...Which to build? piratemike Engine Mods 17 04-25-2003 01:13 PM
Tough Decision, 383 or 406? LD85 C4 Tech/Performance 44 11-18-2002 12:50 PM
Finally fired up the Brodix T1 383... Cory@LS2PortWorks Engine Mods 16 01-04-2002 11:59 PM
Anyone have a 406 in their vette? red86vette C4 Tech/Performance 13 09-02-2001 03:23 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
