Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-16-2003, 05:02 PM   #1
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
Default Ever heard of Piston Guided Rods ?
I just found out from my engine builder that my Carrillo rods are too narrow at .820 wide. Standard Chevy width is about .940 . He was figuring these must be for a Ford engine,
I called the place I bought them from and he says they are a piston guided connecting rod. :confused: He says that this is a trick that many Nascar teams use to get alittle extra HP (~8-10). I need to have pistons made with this option, but I need custom pistons anyhow so that's not a problem.
So have you ever heard of this before ? :cheers:
SmokedTires is offline   Reply With Quote
Old 01-16-2003, 09:10 PM   #2
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
Default Re: Ever heard of Piston Guided Rods ? (SmokedTires)
with this much side clearance you will have so much oil thrown on the cylinder walls the rings will not be able to control the oil burning. SEND THEM BACK this BS!! :chevy
[Modified by clem zahrobsky, 8:12 PM 1/16/2003]
clem zahrobsky is offline   Reply With Quote
Old 01-17-2003, 08:04 AM   #3
SmokedTires
CF Senior Member
St. Jude Donor '05
Default Re: Ever heard of Piston Guided Rods ? (clem zahrobsky)
This is my engine builders concern. He called Carrillo yesterday while I was there because he had never heard it either. They told him that Winston teams are doing this. They're going with thinner rods for the weight savings.
Instead of the large end having .020 clearance on the crank, they control the rod position with the pistons (.001 clearance per side on small end). Carrillo told him we shouldn't have a windage problem if the rods are centered over the oil journal holes. He's not totally convinced at this point & is looking further into it before we decide.
Old 01-17-2003, 11:11 AM   #4
danno85
CF Senior Member
I don't think you would have excessive oil loss and windage with that
much more rod side clearance. The clearance between the bearing and
crank journal is going to control how quickly (and how much) the oil flows out.
The thing that concerns me with the notion of the pin bosses holding
the rod in alignment is that, since the big end of the rod is heavier, that
as it still trys to move back and forth (front to back) that it would rock
the piston sideways in the bore (perpendicular to the skirts), which might
result in accelerated piston wear and potentially uneven bearing wear
as the rod "cocked" back and forth, especially if you had custom forged
pistons w/o any silicon content which would require .005" to .007" skirt
clearance. Remeber that the Winston cup and Nascar engines only have
to run 500 miles.
Would you have to trim the rod bearings to be more narrow also?
I wouldn't use them. Personally I think they are a little "too trick" for any
kind of street engine.
Dan
danno85 is online now   Reply With Quote
Old 01-17-2003, 11:32 AM   #5
Twin_Turbo
CF Senior Member
Default Re: Ever heard of Piston Guided Rods ? (danno85)
with that much side clearance I think the oil will not squirt out in a nice spray pattern to properly lube the walls but it'll probably spray large squirts...
[Modified by Twin_Turbo, 9:54 AM 1/17/2003]
Twin_Turbo is offline   Reply With Quote
Old 01-17-2003, 12:11 PM   #6
gkull
CF Senior Member
gkull's Avatar
I think this is a correct statement. I also think that NASCAR engine guys are thinking of every little thing to get the most power and longevity is not a factor. I would find out if those rods are for a restrictor type motor because less width gives less surface sq. inches. So the bearing loading goes up and longevity goes down.
[Modified by gkull, 11:34 AM 1/17/2003]
gkull is offline   Reply With Quote
Old 01-17-2003, 12:54 PM   #7
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Default Re: Ever heard of Piston Guided Rods ? (gkull)
that is why there is a spec on side clearance is to control how much oil is thrown out of the rods. we tried using wide side clearance on BBC to oil the wrist pins to prevent gauling and we had a oil control problem. JMHO
Old 01-17-2003, 08:18 PM   #8
SmokedTires
CF Senior Member
St. Jude Donor '05
Thanks everyone, there are some very good points here that I will certainly being taking to the vendor. I'm still undecided, but I'm starting to think these may not be the rods :rolleyes: .
Old 01-18-2003, 03:07 PM   #9
Twin_Turbo
CF Senior Member
did you buy them from JR Motorsports? He's about the only one who frequently lists 6"2"rod .928 pin .82 width EDM Carrillo rods w/ 7/16"CARR bolts on ebay :) He does mention it in the auctions.
Old 01-18-2003, 04:42 PM   #10
SmokedTires
CF Senior Member
St. Jude Donor '05
Default Re: Ever heard of Piston Guided Rods ? (Twin_Turbo)
Yes & Yes. It was listed on the auction when I bought them. I just didn't know any better. I am learning quite a bit with this new engine buildup though ;) .
Actually I just bought a set of fully ported Brodix heads from him when I called to question the narrow width on the rods :) .
[Modified by SmokedTires, 2:46 PM 1/18/2003]
Old 01-18-2003, 06:11 PM   #11
Twin_Turbo
CF Senior Member
I'd contact him and ask im if you can trade them in on a set of 6.0 .927 .94 rods, he's got a whole bunch of carrillos and mabe you can work something out.
Marck
Old 01-18-2003, 07:41 PM   #12
SmokedTires
CF Senior Member
St. Jude Donor '05
That was discussed when I talked to him last. I'll probably end up doing that. He assured me that I'd make more power with these rods, & suggested I look into it before giving up on them. He may not be aware that they are for a street driven car though :) .
Old 01-18-2003, 08:47 PM   #13
Twin_Turbo
CF Senior Member
:yesnod: that's what i think too :)
Old 01-19-2003, 10:08 PM   #14
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
a lot of 2 stroke engines use piston located rods so the bottom end roller bearings get enought lube but they also have bronze thrust washers on each side of the rod on the wrist pin end. :chevy
Old 01-20-2003, 12:08 AM   #15
Twin_Turbo
CF Senior Member
Mike,
I have Carrillo 6" .928 small end 2.125 big end .94 width rods w/ 7/16 SPS CARR bolts. They're identical to yours less the EDM and the difference in width. Keep searching, they're out there... wanna bet there will be a set on ebay soon. I think JR only has the .82 ones.
Marck
Reload this Page Ever heard of Piston Guided Rods ?
Tags
60, 716carr, bearing, bolt, cars, chevy, connecting, guided, nascar, piston, pistonguided, rod, rods, thrust, washer
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
