Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-14-2003, 03:52 PM   #1
need-for-speed
CF Senior Member
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03-'05-'07-'09-'10
need-for-speed's Avatar
Default HEI distributor and tach lead question
I want to replace the HEI ignition in my '79 w/ a Mallory Comp 9000 Unilite Electronic distributor. I want to keep the OEM tach functional. I sent this question to the Mr. Gasket (Mallory) tech board. They're answer is a little helpful but also ambiguous. Will it hurt if I hook it up to the (+) if it should be the (-)? See my email to them below along w/ their answer:
I would like to install a Mallory Comp 9000 unilite distributor (mechanical advance) and Pro master coil in my 1979 Camaro. How can I hook up the factory tach. Of course, it currently has a lead that connects to the tach lead on the HEI distributor cap. thanks,
Discussion Topics: ignition
Solution:
I believe the factory tach on that is a neg trigger tach in that case it will go to the neg side of the coil. if it is a pos trigger tach then it will go to the pos side of coil.
need-for-speed is offline   Reply With Quote
Old 01-27-2003, 12:48 AM   #2
need-for-speed
CF Senior Member
CI 1-4-5-8-9-10 Vet
Default Re: HEI distributor and tach lead question (need-for-speed)
Well due to the enormous response to this thread, I thought I would update you guys. I installed the Mallory and hooked up the tach lead to the negative side of the coil and it works like a charm!
Reload this Page HEI distributor and tach lead question
Tags
1979, 9000, corvette, distributor, hei, mallory
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
