Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2003, 08:16 PM   #1
00fxd
CF Senior Member
00fxd's Avatar
Default 454 Balance weights?
There is a manufacturer of a bolt on balance weight that adapts the neutral balance flywheel [manual shift] to work on a 454 and another to work on a sb400. Has anyone used these or know anyone that has? Opinions?
00fxd is offline   Reply With Quote
Old 01-14-2003, 02:08 PM   #2
norvalwilhelm
CF Senior Member
norvalwilhelm's Avatar
Default Re: 454 Balance weights? (00fxd)
Yes there are bolt on weights for the 454 and the 400 but you can take a neutral balanced 427 flywheel and have it lightened on one side for the 454. I bought a steel flywheel and had that done.
As for the bolt on weights I buy parts from a stock car company and in their catalogue they have these weights. It is a offset weight on a plate that gets bolted between the engine and flywheel.
I could get the name off the catalogue and post it if you want. The catalogue is at home.
norvalwilhelm is offline   Reply With Quote
Old 01-15-2003, 02:12 AM   #3
00fxd
CF Senior Member
00fxd's Avatar
Default Re: 454 Balance weights? (norvalwilhelm)
Thanks norval; It would cost a lot to balance the 427 flywheel. I actually thought you had to add weight [mallory metal, expensive]. I'm kinda hopin' this weight idea works o.k. and not be too hokey. Sounds alright for a street engine, but I would like to hear some actual use experiences or some professional opinions before I go for it. Yes, I would like you to find out for me the name of catalogue if you would.
Thanks, Frank.
Old 01-15-2003, 09:02 AM   #4
norvalwilhelm
CF Senior Member
Why does it cost so much to make a neutral balanced flywheel into a offset balanced 454 flywheel? All it takes is about 20 shallow holes drilled to lighten up one side. I have done this myself at home on the work bench by having a stock 454 ring gear and a small bearing and adaptor clamped to the bench.
You put the stock 454 ring gear on the adaptor on the bench and mark where the weight should go then transfer this location to the neutral flywheel and start drilling exactly opposite this location.
With careful checking you can get the flywheel to perfectly match the ring gear or flex plate.
Also any balance shop should be able to do this easily
No metal added just removed.
I will post the company tomorrow morning that sells offset weights for 454's and 400's.
Old 01-15-2003, 11:35 PM   #5
00fxd
CF Senior Member
00fxd's Avatar
Thanks again norval. Like I said, I thought you had to add metal, but your method is something I will definately look into.
Old 01-16-2003, 09:02 AM   #6
norvalwilhelm
CF Senior Member
Balance plates to use a normal neutral flywheel on a 400 or 454 are sold by Coleman Machine Inc. N -1597 US-41, Menominee, Mi 49858. Phone 906-863-7883. Part No for the 454 is 399-101 cost $24.25.
This company stocks part for Nascar and they have a very interesting catalogue of race parts.
This plate sandwiches between the crank and flywheel. It is a precision fit and can only go on one way . It is a offset weight.
Good luck but I still would go with a lightened 427 flywheel
Old 01-18-2003, 03:48 AM   #7
00fxd
CF Senior Member
00fxd's Avatar
Thanks again norval. I've now got all the info I need to make my choice.
Frank.
Reload this Page 454 Balance weights?
Tags
454, balance, weight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Can we talk BIG MOTORS? Any experience with the GM572? Ken Lally C3 Tech/Performance 46 02-24-2005 04:55 PM
internally vs externally balanced hubes Engine Mods 14 01-02-2005 05:48 PM
427 vs 454, what are the dis/advantages? corvettecris C3 Tech/Performance 21 12-17-2004 08:58 PM
Which 454? Obdoc C3 Tech/Performance 32 10-30-2004 06:43 PM
Whats the deal with a Harmonic balancer/ balancing after a stroker?? DieL C4 Tech/Performance 24 07-29-2003 08:38 PM
409 in a SWC???? Cliff63 C1 & C2 Corvettes 13 05-24-2003 12:01 AM
Clutch assembly balance? scool93535 C5 Tech 53 02-13-2003 09:06 PM
Could Someone Please Explain Balancing? bence13_33 C3 Tech/Performance 12 01-06-2002 03:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
