Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2003, 04:16 PM   #1
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
Default My 406 CI Engine Buildup!
Thought some of you guys would like to see the buildup of my 406 that we started yesterday. Took us about 6 hours to get up to the heads. Should be able to get it painted, and ready to drop in the car this week.
Let me know what you think. :cheers:
Here is the link to the first of five posts.. http://forums.corvetteforum.com/zerothread?id=471013
ski_dwn_it is offline   Reply With Quote
Old 01-14-2003, 10:57 AM   #2
gkull
CF Senior Member
gkull's Avatar
Default Re: My 406 CI Engine Buildup! (ski_dwn_it)
I must have missed out sometime. what broke your 350 rings? You have a healthy cam are also going to install some type of stud girdle? If you are I would recomend the Crane. I did run into a fitting problem with the 7/16th rocker nuts supplied with the girdle when used with Comp and Crower cams steel rocker arms.
The locking Allen type Crane nuts were bigger than the rocker shaft machined hole. So I had a machinist buddy use his lathe to make the end of each nut a slightly smaller diameter. I was told that with 3/8th studs this isn't an issue
gkull is offline   Reply With Quote
Old 01-14-2003, 02:23 PM   #3
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
Default Re: My 406 CI Engine Buildup! (gkull)
Thanks for the comments.
I am not going to be using stud girdles. Only gonna be revving to 5600 RPM so I don't think with the ARP 7/16 studs it should be a huge concern. I have read that use of these girdles when not absolutely needed, actually caused a loss in power. :confused:
Thanks again...
Not real sure what broke the 350's rings. Every one of the top rings were broke. I honestly believe the rings were broke when I bought the car 3 yrs ago. I recently spoke with the guy that had the car and he alluded to some cylinder leakage. I can only speculate, but it almost seems like there might have been a problem right from the factory. Like to tight of ring gap. #7 cylinder's top ring was in about 15 pieces when I pulled it out. And the skirt was busted right off. :confused:
The funny thing is the engine did not use one bit of oil or show any real signs of power loss, other than at the track. The average person would have never know the difference. It still ate up camero's mustangs etc like candy on the street/strip. :p: Just wasn't doing what I thought it should. Hence the reason for the MONSTER we are building. I am hoping to get into the 10s with this setup. :cheers:
Old 01-15-2003, 07:56 AM   #4
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
Very :cool: !!! :cheers:
SmokedTires is offline   Reply With Quote
Old 01-15-2003, 11:09 AM   #5
gkull
CF Senior Member
gkull's Avatar
I don't even understand why someone could even think that stud girdles make a loss of power! :confused: Well maybe the bench racer that doesn't have the forethought to understand what they are good for
But anyway the rule of thumb is how much the rocker studs deflect when all the valve are set to lash spec. If you lay a metal straight edge down the side of all your 7/16th studs without rockers in place they should be straight.
Once you start cranking down to set the lash on every one of the rockers. Lay the straight edge and if the studs deflect more than .030 when your rotating the motor over your screwed too not use a stud girdle.
If your studs are bending back and forth. Your rocker tip is side loading the valves and burning up the guides. Also how strong do you think that aluminum head really is with a stud working on aluminum threads. It's more like any deflection is bad and you get the added bonus of not having to worry about your rocker nuts ever going loose.
There is a down side: Tall valve covers and the $150 Crane stud girdle
Old 01-15-2003, 11:15 AM   #6
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
gkull,
Not real sure why they would say that?
Corky has been running his for quite some time and has had no problems, so I would imagine I will be alright too. He has pulled his covers off several time and the valve lash was still in spec.
You make some good points though.... :cheers:
Reload this Page My 406 CI Engine Buildup!
Tags
406, buide, ci, engine
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
406 CI engine buildup! Part 4 ski_dwn_it C4 Tech/Performance 13 01-15-2003 03:29 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
