Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2003, 03:54 PM   #1
johndezman
CF Senior Member
Default hp limit of stock chevy cast pistons
assuming no preignition, no2 or super/turbo charger what would be the limit horsepower/torq wise for stock cast pistons.
my gut syas it would be more rpm related than actual output related. i am i right or _______ against the wind?
johndezman is offline   Reply With Quote
Old 01-14-2003, 02:26 PM   #2
MikeC
CF Senior Member
MikeC's Avatar
Default Re: hp limit of stock chevy cast pistons (johndezman)
Chevy High Performance has a good article in this months issue... I think they got up to 600hp with nitrous before it blew up and that was because of a stupid mistake( purging nitrous into engine at idle.)
The engine made 310hp after they replaced the cam and put new head gaskets in it. they used 325 jets to get 600hp and were starting to use the 425 jets when they screwed the engine up.
Not to say that a stock piston is good up to 600hp.... but it can live for a bit.
MikeC is online now   Reply With Quote
Old 01-14-2003, 03:46 PM   #3
johndezman
CF Senior Member
guess that kind of confirms my gut. i figured if you keep the rpm in line - so you don't jerk the pin boss out of it - the material thickness in the crown should be OK for a great deal. the first failure point i would expect after pin boss - if rpm are reasonable, would be the ring lands...
Old 01-14-2003, 05:48 PM   #4
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
I think 6500 RPM is the max but some go higher :eek:
LD85 is offline   Reply With Quote
Old 01-14-2003, 08:44 PM   #5
johndezman
CF Senior Member
back when i was young and stupid, i had a 58 chevy 348 tri power with a solid cam. when i snugged up the lash i routinely took it to 7000. for a couple of years on the street in the 60's.
i don't know the material specs on that rotating assembly (cast or forged) but it dealt with it for as long as i owned it.
Old 01-15-2003, 07:53 AM   #6
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
For the $$$ why not just go with hypereutectic pistons ? These are a decent middle of the road piston without the forged price. It will also give you some piece of mind without having to worry later :) .
If you don't get CHP, their stock sbc/ nitrous test was pretty impressive ;) .
SmokedTires is offline   Reply With Quote
Old 01-27-2003, 02:48 AM   #7
Russ Bellinis
CF Senior Member
The life/reliability of cast pistons is really based on pressure and rpm more than horsepower. Hold the rpms below 6000, don't use nitrous or a blower and cast pistons will work fine. If you want a blower, nitrous, or to rev above 6000 rpm regularly, you need to go "hyper" or forged.
Russ Bellinis is offline   Reply With Quote
Old 01-29-2003, 02:20 PM   #8
LD85
CF Senior Member
LD85's Avatar
Default Re: hp limit of stock chevy cast pistons (Russ Bellinis)
My compromise is the Eagle 5140 "I" beam for $190 5.7 rod (not 6.0 cause I really want the 5/64 top ring) and the Kieth Black Signature series Hyper's for my 406 engine with miniram. I want to top out at 6000 RPM. Maybe an ocassional missed shift MIGHT spin we to 6500RPM.
Reload this Page hp limit of stock chevy cast pistons
Tags
1999, 406, cast, chevy, highest, hp, limit, limits, max, mods, piston, pistons, rpm, sbc, stock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 04:33 AM
I have Mopar crate engine envy! Flareside C3 Tech/Performance 23 11-27-2001 02:17 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
