Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2003, 12:45 PM   #1
ylose
CF Senior Member
Support Corvetteforum!
ylose's Avatar
Default Engine gurus, would these be ok ingredients for a 383
been keeping an eye out for a 383 assebly that was at a good price.
Can you gents' tell me what your thoughts are on the following?
Quote:
Description NEW 350/383 Crank Stroker kit (internaly balanced) Scat 9000 steel crank ,full race prepped,3.750 stroke ,cross drilled mains ,knife edged. 8-New Eagle 4340 forged I-beam rods 6.000 long, bronze bushed small ends,dowel pinned caps ,ARP wave lock bolts loaded. 8-New K-B hyper pistons ,flat tops,full floating pins ( RATED TO 600+ HP.) ALL NEW IN THE FACTORY BOXES $850.00 COMPLETE
my current setup is : http://temp.corvetteforum.net/c3/ylo...inespecs.shtml
I would be looking to reuse my top half with this assembly and my core bored and prepped..
thanks guys.
:cheers:
ylose is offline   Reply With Quote
Old 01-13-2003, 01:21 PM   #2
MoMo
CF Senior Member
MoMo's Avatar
Default Re: Engine gurus, would these be ok ingredients for a 383 (ylose)
I think it sounds like a pretty solid combo. One thing I might add are ARP main studs. If you have nodular iron caps, that should be okay for a street motor, but if you plan on actually approaching 600 hp with a street/strip approach, may not be a bad idea to machine your block for 4-bolt splayed billet caps. Or if already a 4-bolt, then just use ARP main studs and call it good.
The hypereutectic pistons are a good street choice, maybe the best for street. And they will take more punishment than cast pistons. However, they are not as "elastic" at the limit as forged pistons, so if you are going to street/strip the engine and apply nitrous, supercharger, or turbos, then jump for the better forged pistons.
Your heads and intake are fine. Perfect for a street set up. Once again, if you are building for the strip, you might step up on your intake manifold choice. An Edelbrock Performer RPM or Performer RPM Air Gap is probably your best choice. Your website did not say what type of intake you have.
I think you'll see at least 450 lb-ft of torque, and the horsepower will depend on the rpm you design the engine for. :auto:
MoMo is offline   Reply With Quote
Old 01-13-2003, 01:27 PM   #3
ylose
CF Senior Member
ylose's Avatar
Default Re: Engine gurus, would these be ok ingredients for a 383 (MoMo)
Thanks MoMo,
I have Arps all around currently....
prob won't ever do Nitro, and will be looking to stay street rather than strip...
currently runnin' the Edel air/gap also....so looks like I am doin' ok so far...
its nice to keep some money in the wallet for when the woman goes a-shoppin'
thanks...
:cheers: :lol:
Old 01-13-2003, 01:37 PM   #4
gkull
CF Senior Member
gkull's Avatar
It should be a nice setup. It will really tame down your cam. With all identicle components and the only change is displacement. Your hp will be the same, but at a lower rpm. Your foot pounds of tq will go up.
Your compression will go up, but your well within the limits of being able to use 91 octane or what ever the octane is in your area.
gkull is offline   Reply With Quote
Old 01-13-2003, 02:07 PM   #5
ylose
CF Senior Member
ylose's Avatar
Default Re: Engine gurus, would these be ok ingredients for a 383 (gkull)
good....thanks gkull, I was worried about that too....don't want to overstep myself from being able to use pump gas and settling my cam some would be nice for idle...oh wait....who the hell idles in a vette !!! :eek: :lol:
Old 01-13-2003, 02:45 PM   #6
redvetracr
CF Senior Member
redvetracr's Avatar
J.
There is a guy in Delavan (Pete the porter) who could probably clean up your heads and intake for a little bit better flow. I can get you his ## if you wish. HN
redvetracr is offline   Reply With Quote
Old 01-13-2003, 05:19 PM   #7
ylose
CF Senior Member
ylose's Avatar
Default Re: Engine gurus, would these be ok ingredients for a 383 (redvetracr)
hrm......and here I thought I would save some mola by not touching the upper half and you have to go and mention a way to get more ponies ..... :cuss
:lol:
Old 01-14-2003, 09:29 AM   #8
arnold
CF Senior Member
Don't know what torque or rpm limits you are setting for yourself , but in case you are not aware, that is a cast crank, and there are different levels of Eagle rods available.
arnold is offline   Reply With Quote
Old 01-14-2003, 10:58 AM   #9
ylose
CF Senior Member
ylose's Avatar
Default Re: Engine gurus, would these be ok ingredients for a 383 (arnold)
Thanks arnold.....I think I am going away from this deal.....for a few more dollars more I can get forged crank and better rods as you mentioned....sticking with 4340 materials and all...
but at least the 383 seems to be the way to go and not have to redo everything.... :cheers:
Old 01-26-2003, 03:02 PM   #10
MoMo
CF Senior Member
MoMo's Avatar
:confused:
You mentioned this engine was a street set up. And that you wanted to save money by not having to trick out the motor. So why are you stepping away from it because of a cast crank, and the desire for better rods?
The forged I-beam rods and cast steel crank should be more than fine for a street set up.
The 465 in my Pontiac Firebird has a cast iron crank and cast steel rods, and it makes a lot more power than a 383, and I haven't had a lick of trouble with it, ever. I think you'd be fine. Save the money, IMO.
Old 01-26-2003, 03:35 PM   #11
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Quote:
:confused:
...Save the money, IMO.
EXACTLY!!!
Even with an upgraded top end, you will have to get pretty serious to over tax this rotating assembly. Good luck...and
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Reload this Page Engine gurus, would these be ok ingredients for a 383
Tags
a383, ingredients
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
