Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-12-2003, 10:28 PM   #1
challenger818
CF Senior Member
challenger818's Avatar
Default Engine Recipe
I'm looking to build a new motor to beat the street racers at there own game. the motors gona be a Big-Block between 509 and 632 (if i really find some dollars). It's gonna run though ported ported exhaust manifolds to maintain stealth. The tranny will prolly be a TH-400 or 4L80. Low engine torque is not all that important because of the cubes and becuase of the "unprepared track surfaces" Can anyone recommend a solid or solid roller cam, heads and any other tips, ideas or parts that I may have over looked. Also a TQ converter recommendation or if you think i should use a manual tranny wil be helpful.
thanks,
Challenger
challenger818 is offline   Reply With Quote
Old 01-16-2003, 12:32 PM   #2
wallyknoch
CF Senior Member
wallyknoch's Avatar
Send a message via AIM to wallyknoch
Default Re: Engine Recipe (challenger818)
Just build it like a LS7. Flat tappet 600 lift cam, Dart heads {you will need longer head bolts and pushrods} 12.5 compression, L88 intake or better and a 850 dual feed Holley. and Hooker comp headers. A stock HEI distributor will work fine. Stay away from roller anything except timing chain set. 38 degrees advance, and a stock fuel pump from L88`s. If using a turbo 400, a 3500 stall converter will be fine. It should idle at around 900 and blow most pump jockeys in the weeds. Gas is the only problem. Aviation 100 from your local airport will do the job. Last thing is go to at least a 4.10 gear then buckel up and hang on. You wont be dissapointed. :thumbs: :auto: :cheers: :D
thanks,
Challenger
wallyknoch is offline   Reply With Quote
Reload this Page Engine Recipe
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Horsepower for a L98 engine michelc4 C4 Tech/Performance 42 06-14-2010 07:14 PM
Recipe for a 300HP rebuild on an 80 L-48? 88BlackZ-51 C3 Tech/Performance 17 03-14-2004 11:13 PM
Turbo charged Grand National Engine in a C-4? black86z51 C4 Tech/Performance 57 06-09-2003 12:36 PM
Need recipe for 500 rwhp JCOB2 C5 Tech 23 01-10-2003 03:03 PM
Feedback requested -- 502 engine recipe Hank Engine Mods 10 12-29-2002 09:40 PM
OK- may have found my engine recipe, comments please. SmokedTires Engine Mods 21 12-18-2002 08:04 PM
How long did it take your engine builder to port your heads & build your engine? Classicvette63 Engine Mods 22 06-28-2002 09:37 AM
Recipe for a 12 second L98 Sal Collaziano C4 Tech/Performance 74 09-09-2001 02:31 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
