Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-12-2003, 02:25 PM   #1
Doug2500
CF Senior Member
Default Can I run a Dry Sump off the water pump?
Because I'm limited in space and a have blower pulley on the crank nose, wondering if there is a problem running a dry sump off the front of the water pump.
Realize that I'll need to adjust the pulley to make sure the dry sump runs at the right speed.
Doug2500 is offline   Reply With Quote
Old 01-12-2003, 02:45 PM   #2
Twin_Turbo
CF Senior Member
Default Re: Can I run a Dry Sump off the water pump? (Doug2500)
Are you running a gilmer pulley on the crank & blowe? Why not install a larger belt and run the dry sump pump off it too.
Twin_Turbo is offline   Reply With Quote
Old 01-13-2003, 03:48 PM   #3
Doug2500
CF Senior Member
Default Re: Can I run a Dry Sump off the water pump? (Twin_Turbo)
It all comes down to available spaced and matching the belt types. The dry sump pump uses a Gilmer belt.
The SC uses a dual, narrow serpentine belt , and the crank pulley for the SCis rather large which will would turn the dry sump pump much faster than it was designed for. I could put a larger pulley on the dry sump, but then I don't think it will fit in the car.
Old 01-13-2003, 05:48 PM   #4
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
if you drive the WP with a gilmore belt to prevent slippage it should work,but it will put a big load on the WP:chevy
clem zahrobsky is offline   Reply With Quote
Reload this Page Can I run a Dry Sump off the water pump?
Tags
dry, pump, run
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 01:59 PM
dry sump pump bigcityvette Engine Mods 10 08-21-2005 02:51 AM
SGC TT ZR1 - BOOSTAMUV!! Rkreigh C4 ZR-1 Discussion 168 04-05-2004 01:50 AM
What would be your Ultimate Dream Small Block? John Dirks C3 Tech/Performance 23 09-10-2001 11:00 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
