Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-16-2002, 09:47 AM   #1
madvette74
CF Senior Member
madvette74's Avatar
Default PROFORM is it really good for 25-50hp ( who has one)
i have a 700 mechanical secondary holley, the car has unbelievable pull, at 30-35mph i can punch it and get the car sideways, lots of torq, i want to enhance performance, just a bit, will this proform acually flow more cfm than my engine needs, i got the 700 holley because i thought the 750 would be overkill, my major question is will i loose any bottem end, in the result of gaing top end hp and tq
madvette74 is offline   Reply With Quote
Old 11-16-2002, 06:00 PM   #2
Jughead
Senior Member since 1492
St. Jude Donor '09
Support Corvetteforum!
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell...3.Spare me the Lima Beans.
Send a message via AIM to Jughead
I've been using one for about a year now. I think the 20-50HP claim is a little exagerated. I'm using it because I needed a card body without the choke/tower. It was cheaper than buying a new carb. Honestly though, I can't say anything bad about it. It holds an idle better, has better throttle response and once warmed up really sings. Plus I like the look. I put it on my 3310 750 vac sec.
Jughead is offline   Reply With Quote
Old 11-16-2002, 09:31 PM   #3
madvette74
CF Senior Member
madvette74's Avatar
Default Re: (1970 Stingray)
how did you get the rest of your holley to look silver?? also i was just about to post a message on who has a cobra gas cap,lol awsome!! i see you have one, do you have more pics of it, and where you got, i been wanting to install one for years, and i been trying to research on the parts and ect, any info would be a great help
Old 11-16-2002, 09:52 PM   #4
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
Default Re: PROFORM is it really good for 25-50hp (madvette74)
it depends on how bad the casting flash or die alignment in the venturi area is. i have seen 25+ hp difference in holley carbs where we were not allowed to do any cleaning up of the venturi area because of the race track rules. finding a old carb that was built before the dies wore out made the difference. :chevy
clem zahrobsky is offline   Reply With Quote
Old 11-16-2002, 10:02 PM   #5
Jughead
St. Jude Donor '09
Jughead's Avatar
Default Re: (madvette74)
My 3310 started out life with the silver-chrome finish---not really my preference but...
I got the fuel filler from http://www.cobraaccessories.com then look under the Cobra section. This was a very difficult project, involving a lot of measuring & re-measuring. You can read more about the adaption & installation at http://temp.corvetteforum.net/c3/the...t/index7.shtml
Without Rolling Thunder at the helm, the project would have never completed. Thanks Dave!
:cheers: :flag
Old 11-16-2002, 10:32 PM   #6
madvette74
CF Senior Member
madvette74's Avatar
i checked both sites out, did you also buy the base from them?? i looked at the pics of the cap it looks like a solid base, but the web site say's there base consist of a screw type with 2inch hose, i tried to downlod the doc file, but when i do it's unreadable, did you make up your own base??
Old 11-17-2002, 09:50 AM   #7
Jughead
St. Jude Donor '09
Jughead's Avatar
All the credit goes to rolling Thunder. He had the flanges machine to custom fit our Vette's. The problem with their adapter base is that it's about 2 inches short. A new gas tank flange would need machined.
I bought the base from Cobra Accessories but couldn't use it. At the other link above I gave a brief description of the process. Essentially Dave bought a solid 6x6 block of aluminum($$) for mine & brass($$) for his. He then had a machine shop make the new flange. The base of the flange bolts directly to the tank and the flip-top filler then screws on to the new, taller flange. I'm sure there may be other ways to accomplish this and there are some guys who have the flip-top filler simply attached to the rear deck.
Dave & I wanted the flip-top to be completely functional and open directly into the tank. One thing we discovered in this project is that gas tanks vary. Some flange bases of the tank are tilted 15 degrees and some are flat. A while back I spotted a filler neck from a C2 coupe which I though might work---not sure of the dimensions & it mating to the filler cap. Maybe that's something you could check out.
Reload this Page PROFORM is it really good for 25-50hp ( who has one)
Tags
filler, neck, proform
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
