Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-15-2002, 02:33 AM   #1
SRVFAN7
Junior Member
SRVFAN7's Avatar
Send a message via AIM to SRVFAN7
Default Crank
Yea I bought an eagle crank (3.48",large journal). Very awesome crank =) I also have the eagle h beam 6" rods. The rods are made for large journals. I looked at the part number on the crank they sent me and it says its for the 5.7" rods. Is this gonna make a difference? I mean the journal sizes are the same...Does it matter if the rod is 5.7" or 6" for the crank? I know on the eagle site they have 2 different listings for a 2.1 journal, 3.48" stroke one for the 5.7s and one for the 6s. I hope this isnt gonna matter cuz i dont feel like sending it back...If you guys know please tell me! Thanks...
Tony
SRVFAN7 is offline   Reply With Quote
Old 11-15-2002, 07:35 AM   #2
DeenHylton
CF Senior Member
DeenHylton's Avatar
Default Re: Crank (SRVFAN7)
I'd be getting on the phone and making a call to Eagle to make sure. I believe that if you use the combination you have now that even a flat top piston would be sticking above the top of the block...instant damage the instant you tried turning the engine over, if you could even get it assembled to begin with! So it sounds like you need to ship the crank back or get different rods. Deen
DeenHylton is offline   Reply With Quote
Old 11-15-2002, 08:07 AM   #3
GregP
CF Senior Member
GregP's Avatar
Stroke is stroke, so the crank won't "appear" to know the difference in rod lengths (the rod length difference is accomodated at the pistons), it would assemble and look "ok". The difference in the cranks for different rods is in the balance. I'd get the correct crank or you may have a lot of trouble getting it balanced.
-Greg
GregP is offline   Reply With Quote
Old 11-15-2002, 09:37 PM   #4
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Sorry, DeenHylon, but that is all wrong. A crank of a given stroke won't push the piston any further than its stroke. The pistons DO have to be matched to the stroke and rod length. A shorter rod will allow the piston to come closer to the counterweight. Go ahead and call Eagle, but I think you'll be fine using a longer rod than the "specified" catalog length. The other way around, you'd have a problem with the pistons hitting the counterweights.
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Old 11-16-2002, 04:24 AM   #5
jackson
CF Senior Member
Default Re: Crank (GregP)
-Greg
That's right ... difference is in the balance ... which needs to be corrected. As mentioned, the difference in rod length is accomodated by the pistons. 6" & 5.7" pistons are like apples & oranges. Make sure you have the correct pistons for 3.48" stroke ... 6" rod pistons have a compression distance of about 1.260" ... 5.7" rod pistons have CD about 1.560". Standard sbc block's deck height 9.025". So, half of stroke is 1.74" + 6" rod + 1.260" CD + about 0.025" deck clearance (aka "piston down in the hole") = 9.025"
[Modified by jackson, 3:53 AM 11/16/2002]
jackson is offline   Reply With Quote
Old 11-16-2002, 12:22 PM   #6
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
any crank you buy must be balanced to the rest of the rotating assy. only if you buy a complete rotating assy that is balanced from the supplier you will not have to have the assy balanced. pistons for long rods weight less than pistons for std length rods so you have to balance the crank to the pistons and rods unless you want a "shaker" some times the difference in the cranks for 5.7" rods vs 6" is the size of the counter weights so they clear the pistons at BDC. :chevy
clem zahrobsky is offline   Reply With Quote
Old 11-17-2002, 04:06 AM   #7
SRVFAN7
Junior Member
SRVFAN7's Avatar
So, I can just keep this crank and have the machine shop balance it?
Old 11-17-2002, 11:58 AM   #8
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
yes you will need to take your pistons and pins,rods,rings,and rod bearings to the balancer so they can know what bob weights to use when balancing the crank. :chevy
Old 11-17-2002, 01:21 PM   #9
SRVFAN7
Junior Member
SRVFAN7's Avatar
Default Re: Crank (clem zahrobsky)
Yes, I know about taking it to get balanced...but is it OK to keep this crank that was sent to me for 5.7" rods when I will be using it for 6" rods I have? Would it be better to exchange the crank for the one made for 6" rods or can I just have this one balanced? Thanks
Old 11-17-2002, 02:24 PM   #10
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
*I* see no problem, but check with Eagle and/or your machine shop, first.
RACE ON!!!
Reload this Page Crank
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
GM doesn't know about Crank Bolt Recall??? c64lucky C6 Corvette General Discussion 19 03-31-2011 05:01 PM
Crank Bolt Issue--VIN Numbers surburban99 C6 Corvette General Discussion 27 06-26-2005 04:54 PM
Crank pulley: only vote if you've had trouble mikeyc6 C6 Corvette General Discussion 85 06-23-2005 07:09 PM
Crank Pulley spectra6.0 C6 Tech/Performance 69 06-04-2005 07:55 PM
Crank bolt happened at 65 MPH!!! VNAMVET C6 Tech/Performance 102 05-06-2005 08:57 PM
Crank pulley NEWSFLASH. b/dates & Vins sheck11 C6 Corvette General Discussion 141 05-01-2005 10:06 PM
Crank Pulley Update SHOOTER 49 C6 Corvette General Discussion 79 12-11-2004 10:37 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
