Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-14-2002, 11:06 PM   #1
joe73vette
CF Senior Member
joe73vette's Avatar
Default Max lift with Vortec heads?
What's the real story with vortec heads?
Scoggin-Dickey says they can't take over .450 lift, but they want to sell their modified heads with Z28 springs and LT4 retainers.
GMPP uses a .435/.460 lift cam in their 350HO crate motor.
Chevy High Performance says max of .470 lift.
I want to use Comp Cams 265 Dual Energy .442/.465 lift or XE262 Xtreme Energy .462/.469 lift. Will either work?
What cams have you people been using with Vortec heads?
Thanks,
Joe
PS Is it the springs or the guides that limit valve travel? If guides, can they be hand worked a little?
[Modified by joe73vette, 10:17 PM 11/14/2002]
joe73vette is offline   Reply With Quote
Old 11-15-2002, 09:14 PM   #2
1MoorTym
CF Senior Member
Default Re: Max lift with Vortec heads? (joe73vette)
[QUOTEChevy High Performance says max of .470 lift.[/quote]
Thats not what they say in the Jan 2003 article. "The stock springs will only accommodate around 0.420 inch of valve lift".
I can see why you're confused. Check out the article though, it should hopefully answer more questions then it raises.
1MoorTym is offline   Reply With Quote
Old 11-16-2002, 10:29 AM   #3
torqueman2002
CF Senior Member
torqueman2002's Avatar
I'm using Vortec heads (12519093; https://www.spoperformanceparts.com/) on a 383 for my Bronze 84.
See Vortec Head assemblies (p/n: 12558060) for Technical Notes.
I'm using CompCam's (LT1 XR269HR-12 grind, p/n: 07-502-8). It has a gross lift of 0.495 Intake, 0.503 Exhaust.
Valve bind is a problem with the Vortec heads and this much lift, the maximum camshaft lift is .475". To avoid cutting the spring pockets Crane Cam 99846-16 springs are used.
Crane Cam technical notes---> "The 99846-16 springs are made from H-11 Tool Steel and provide open pressures of up to 350 lbs. at 1.175" open height. These "stock diameter" springs for small-block Chevys can be installed in stock spring pockets without machining or removal of the cylinder heads. Stock spring retainers can be used, but we recommend our Crane steel retainers and machined steel valve locks for maximum strength. The 99846-16 spring is engineered to handle up to .585" gross valve lift .... " http://www.cranecams.com/master/vsprings.htm
BTW; GM Performance Parts is having a "Garage Sale" until the end of the month.
http://www.gmgoodwrench.com/dhtml/pa...ragesale.shtml
Many parts are on sale: 355 hp ZZ4 5.7L engine, the ZZ502/502 Rat; the bare Vortec Heads (p/n:12519093) are $206.17 each; the Vortec Head assemblies (p/n: 12558060) are $245.06 each.
:cool: :chevy
[Modified by torqueman2002, 2:35 PM 11/16/2002]
[Modified by torqueman2002, 2:37 PM 11/16/2002]
[Modified by torqueman2002, 2:38 PM 11/16/2002]
torqueman2002 is offline   Reply With Quote
Old 11-18-2002, 06:59 PM   #4
No Go
CF Senior Member
I agree...what is the actual lift capability!
The magazines have royally screwed up the facts on this one...:)
No Go is offline   Reply With Quote
Reload this Page Max lift with Vortec heads?
Tags
350, 470, head, heads, high, home, hp, lift, max, maximum, mods, pockets, spring, stock, vortec, vortech
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help..New GMPP Vortec Heads? 69vettester C3 Tech/Performance 23 07-04-2005 09:30 PM
Vortec Heads ENGINE TROOP C4 Tech/Performance 14 10-14-2003 06:01 PM
Are Edelbrock Performer RPM heads suitable for a 383? 7t2vette Engine Mods 16 06-16-2002 10:23 AM
T.P.I. with vortec heads? corvette4life C4 Tech/Performance 18 05-04-2002 10:09 AM
Performance heads for stock 85???? dtorc4 C4 Tech/Performance 27 12-08-2001 03:50 PM
Need help selecting Heads! Rob's 73 C3 Tech/Performance 16 10-16-2001 01:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
