Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-12-2002, 09:31 AM   #1
aharte
CF Senior Member
aharte's Avatar
Send a message via AIM to aharte
Default Mods to get to 7k rpm?
Is it possible to get 6500-7000 rpm's out of an old L82 if the top end is made to handle it, or does it need to be ripped apart and rebuilt first? I'm thinking of getting AFR heads and some other stuff, which would gain a lot more if I could rev the engine higher.
aharte is offline   Reply With Quote
Old 11-12-2002, 04:32 PM   #2
Crazyhorse
CF Senior Member
Crazyhorse's Avatar
Default Re: Mods to get to 7k rpm? (aharte)
I'd say you'd want a complete rebuild, but...
6.5 - 7K RPM's is not really what you should be aiming for on your car.
Just select the proper components that will work well together to
increase HP & torque. Don't get hung up on what the red line will be.
A good investment would be desktop dyno to model your components with.
[Modified by Crazyhorse, 3:33 PM 11/12/2002]
Crazyhorse is offline   Reply With Quote
Old 11-12-2002, 06:43 PM   #3
gkull
CF Senior Member
gkull's Avatar
My 79 l-82 short block stock made numerous runs to 7000+ rpm with various head and cam combos. So the stock forged crank and rods can handle it if the motor has been well maintained. I still have that crank and rods and plan on using them in some future project 355 ci. Although this rebuild they would get ARP rod bolts and of course a really nice balance job.
7000 rpm requires attention to spring closed pressure and valve train weight.
gkull is offline   Reply With Quote
Old 11-13-2002, 12:08 AM   #4
aharte
CF Senior Member
aharte's Avatar
Default Re: Mods to get to 7k rpm? (Crazyhorse)
I actually have desktop dyno already, and that's what prompted the question. Putting on a good set of heads with the current cam (I think its stock, but I'm not sure right now) and right intake/exhaust creates peak power around 6500 according to the program (and a lot of it).
It would also help some of my gearing issues. I'm ditching the 700r4 for an M20 or M21. I have a 3.08 rear, which gives a max speed of 140 mph at 5500 rpm. That's fine, except that I'd like deeper gears while keeping that top end. I don't like the ratios on the overdrive transmissions enough to justify the price.
Old 11-13-2002, 12:14 AM   #5
aharte
CF Senior Member
aharte's Avatar
Default Re: Mods to get to 7k rpm? (gkull)
Thanks gkull. How much power did that setup put out?
Old 11-13-2002, 08:16 AM   #6
Twin_Turbo
CF Senior Member
The big end on the rod will be critical & the rod journal size too. You will have to get the rods resized because they tend to get egg shaped, mike the journals, then you can get the bearing clearances right. A lot of them have 0.0005" oversize bearings from the factory to take up for machining tolerances.
Marck
Twin_Turbo is offline   Reply With Quote
Old 11-13-2002, 02:46 PM   #7
gkull
CF Senior Member
gkull's Avatar
The fastest 355 ci combo I ever had was 12.38 @114 with slicks. I have a 4.11 rear and 700R4. Instead of a manual tranny it would be cheaper for you to install what i consider to to be the best gearing for a 700R4 and that's a 3.90 rearend. It gets your overal gearing in OD to about the 2.73 range. With 28 inch tall tires you would have to have a powerful 355 to ever hit 6500 rpm in OD and a big set of nut's ;) I have driven my car for extended periods at 6500 rpm
Old 11-13-2002, 03:53 PM   #8
aharte
CF Senior Member
aharte's Avatar
I'm not really putting in the manual transmission for any performance benefit, although I do think they're superior for road racing, which is mainly the type of driving I do. Manuals are just a lot more fun in my opinion.
Old 11-13-2002, 05:45 PM   #9
gkull
CF Senior Member
gkull's Avatar
I help a friend convert his 78 to a stick. I was a PITA. It took a little bit to aquire the petals etc, but installing them was a job designed for a midjet contortionist.
I had a 700 with a full manual valve body. It's like a clutchless 4 speed. I drive a 5 speed nearly every day if I don't take my Vette. Manuals are fun :seeya
Reload this Page Mods to get to 7k rpm?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steal this 99 6spd vert...with Supercharger TANGLVR C5 Corvettes for Sale 34 07-23-2005 09:21 AM
beginning mods for a LT4? spinedoc C4 Tech/Performance 20 08-27-2003 08:11 PM
Hey you daily drivers!!! What is out there for high mileage MN6s? scorp508 C5 Corvettes for Sale 17 11-19-2002 12:53 AM
Heads & Cam Owners...Help Please John Nowak PE C5 Tech 21 10-31-2002 02:29 PM
TPI mods for more RPM's Chevyguy1984 C4 Tech/Performance 13 10-29-2002 04:57 PM
Any downside to owning a zr-1? xzvs C4 Tech/Performance 81 06-30-2002 08:50 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
