Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-12-2002, 01:16 AM   #1
WashingtonRacer
CF Senior Member
Send a message via AIM to WashingtonRacer
Default Another internal balance question?
I am confused. I spoke with the local shop regarding an Eagle Rotating kit, they stated that I would need to bring in my balancer and flywheel in order for them to balance the whole thing. Now I am speaking with a guy at Gofastparts.com, and he is offering a much better price, but he says that they can balance the whole kit there, and that I do not need my balancer or flywheel for that. can someone enlighten me on this, as to which is true, and which is better and safer for high rpm's
WashingtonRacer is offline   Reply With Quote
Old 11-12-2002, 02:52 AM   #2
jackson
CF Senior Member
Default Re: Another internal balance question? (WashingtonRacer)
Makes no difference whether external, neutral or internal balance.
They’re both “right” ... but assuming your local balancer does class A work ... local guy is more correct. Balancing with damper & flywheel is better & safer.
Think of tires ... they need balancing ... but the weights seldom if ever go in the same places ... tires are a VERY EXAGGERATED EXAMPLE.
Dampers/flywheels/flexplates balance points are more or less standardized. But there are variances between manufacturers, sizes, models, even from lot-to-lot within a specific mfg’s pn. The mail order guy is using HIS “standard” to do the balance job ... it’ll probably be close ... but probably not a perfect match to the balance point of YOUR damper & flywheel. Your local guy will use YOUR damper & flywheel to more closely attain that perfect balance. For best result, a class A job using YOUR parts is best.
BTW, I’d pre-assemble entire rotating assembly into block (LESS rings, wristpin locks, damper & flywheel) along with DEGREED cam-timing set BEFORE any balance is done. Also check valve-to-piston clearance. You’ll wanna know if there’s any part of that assembly that might need grinding/machining BEFORE you have it balanced ... in strokers there are often cam-to-rod clearance issues. Make certain the damper & flywheel you choose are correct & in good condition ... BEFORE you have it all balanced. Also, having a set of old "sacrificial" rod & main bearings are nice to have during the pre-assembly as they can get damaged ... save the good ones for the balance and final assembly. Also, have your local guy check that the bearings you use are appropriate for the radii of new crank's journals. Hope this helps.
[Modified by jackson, 1:57 AM 11/12/2002]
jackson is offline   Reply With Quote
Old 11-12-2002, 10:11 PM   #3
WashingtonRacer
CF Senior Member
Default Re: Another internal balance question? (jackson)
WOW!!!! thanks for the information!.. That answers my question. I will order the kit from the mail order guy, then take it all in to the local shop to have it done. I called them today making sure I would recieve a spec sheet specifying each of the rotating parts and their weights. They do that, so I will be happy. I do feel bad however since I never actually buy something from the shop. I really like their information, but their prices can always be beat. Only times I have really used them is when I need some machine work done. oh well.
Anyways once again, thanks for all the tips. I I should start putting this all into action shortly.
Reload this Page Another internal balance question?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 72 11-21-2011 03:50 PM
Which Machine Shop Services are a waste of $$ 79vetter C3 Tech/Performance 20 08-03-2005 01:36 PM
Can someone list the differences between 2000 - 2001 C5 ? dumbkid C5 Tech 12 07-19-2002 08:17 PM
To 383 or not 383, that is the question. So what's the answer? joeveto C3 Tech/Performance 44 05-12-2002 01:28 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
