Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2002, 02:28 PM   #1
redvetracr
CF Senior Member
redvetracr's Avatar
Default Valve covers w/oilers
Anyone using them?? And have you noticed a difference??
...redvetracr
redvetracr is offline   Reply With Quote
Old 11-08-2002, 07:58 PM   #2
gkull
CF Senior Member
gkull's Avatar
Default Re: Valve covers w/oilers (redvetracr)
All my buddies Sprint cars use them. Springs die from heat. You said that you had two broken springs. Maybe yours will last longer and maintain a more consistant spring pressure with oilers.
[Modified by gkull, 5:04 PM 11/8/2002]
gkull is offline   Reply With Quote
Old 11-08-2002, 09:38 PM   #3
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
they are mostly used in circle track racing because the "G" forces in the turns keeps oil from getting to the springs. these were first used by chevy at the indy 500 with the stock block chevys because they were burning up the springs at the brickyard. :chevy
clem zahrobsky is offline   Reply With Quote
Old 11-09-2002, 12:22 PM   #4
Monty
CF Senior Member
Monty's Avatar
I've got them in my fabricated billet valvecovers. I use them because I run .100" restrictors due to the solid roller cam. The valvespring oilers allow me to still direct an adequate supply of oil to the springs and Jesel shaft rockers for cooling and lube, without overwhelming the topend with an unnecessary volume of oil.
I've got a set of the GM Performance Parts cast aluminum covers with valvespring oilers in them, you can have them if you want. They were set up for a dry sump system, so there's a 1/2" hole for a scavenge line, but it can be easily plugged. I don't need them since I ahve the billet covers.
Monty is offline   Reply With Quote
Reload this Page Valve covers w/oilers
Tags
covers, gm, oiler, oilers, performance, sbc, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any N/A Lt-1's making 500 rwhp? Kehrer923 C4 Tech/Performance 75 07-26-2005 01:54 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
