Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2002, 10:45 AM   #1
Ken73
CF Senior Member
Cruise-In III Veteran
Ken73's Avatar
Default Pistons are in...
And yes, that's Glyptal (electric armature enamel) in the valley..
I put all ARP hardware on the bottom (main studs, new rod bolts.)
Hopefully it'll be to this stage in the next month.. I just set everything on to see how it'd look...
:cheers:
Ken73 is offline   Reply With Quote
Old 11-08-2002, 09:05 PM   #2
redwingvette
CF Senior Member
redwingvette's Avatar
Send a message via AIM to redwingvette
Default Re: Pistons are in... (Ken73)
Looking good. What heads are you using?
redwingvette is offline   Reply With Quote
Old 11-09-2002, 12:17 AM   #3
Ken73
CF Senior Member
Ken73's Avatar
Default Re: Pistons are in... (redwingvette)
L98 heads off of a '90 Vette that I bought from a forum member. The exhaust guides were a bit worn but I didn't expect them not to be, really. Exhaust guides tend to wear faster; I'm having bronze sleeves put in the exhaust, and I'm going to ceramic coat the heads just like I did with the pistons.
Old 11-17-2002, 03:41 PM   #4
69stingray
CF Senior Member
69stingray's Avatar
What manifold is that?
69stingray is offline   Reply With Quote
Old 11-17-2002, 07:37 PM   #5
Jughead
Senior Member since 1492
St. Jude Donor '09
Support Corvetteforum!
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell...3.Spare me the Lima Beans.
Send a message via AIM to Jughead
Looks good! :yesnod: You have about as much garage room as me! :lol: :lol:
Jughead is offline   Reply With Quote
Old 11-17-2002, 09:06 PM   #6
Twin_Turbo
CF Senior Member
Default Re: Pistons are in... (69stingray)
That's a crossfire manifold with custom lid :)
Twin_Turbo is offline   Reply With Quote
Old 11-18-2002, 06:41 PM   #7
Bink
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '09
Bink's Avatar
What cam are you using? Looks great BTW! Congrats! :cheers:
Bink is offline   Reply With Quote
Old 11-18-2002, 08:12 PM   #8
mackeyred96
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
mackeyred96's Avatar
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
john mackey
:cheers: :cool:
mackeyred96 is offline   Reply With Quote
Old 11-22-2002, 04:39 PM   #9
Ken73
CF Senior Member
Ken73's Avatar
Default Re: Pistons are in... (binksZ06)
I'm using a Crane Fireball 290 cam - it doesn't make any sense to use this cam on most cars, but it will work VERY well on a CrossFire with the single pattern. Specs are 216/216 @.050", 290/290 (advertised) 110LCA, .454"/.454" lift. I've got 1.6:1 roller-tip (stamped steel) rockers to go with it.
And yes, that's a custom lid I made out of phenolic sheet to get rid of all the junk on the underside of the stock lid (so it's smooth) and reduce heat that gets transferred to the throttle bodies.
Reload this Page Pistons are in...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
[UPDATE] Single Plane Intake Results are in........ ski_dwn_it C4 Tech/Performance 35 11-18-2003 12:24 PM
Dyno results are in: 69ttop502 Engine Mods 13 10-31-2003 04:48 PM
Dyno results are in 69ttop502 C3 Tech/Performance 18 10-21-2003 10:19 AM
New Dyno Numbers are in! KJL C3 Tech/Performance 18 09-19-2003 01:29 PM
New 383 engine specs are in.... Z06_BluByU C4 Tech/Performance 19 07-24-2003 09:28 AM
Finally, pistons are in.... Jughead C3 Tech/Performance 18 06-01-2003 03:59 PM
updated pics of new motor..pistons are in PatsLs1vette C3 Tech/Performance 12 04-23-2002 09:31 PM
Pistons Are In! bence13_33 C3 Tech/Performance 19 03-10-2002 06:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
