11-08-2002, 09:48 AM
CF Senior Member
Re: Mini Ram ?'s Again! (91L98Vette)
there is one company that makes a lower gear than 3.33 for the D36, but i dont have the website so you might get a 3.54 made for it. However, you still cant run slicks at all, or youll risk it blowing up
youll need at least a zz9 cam, but the cam choice depends on power you want
The heads will need to be ported to take advantage of the cam. Headers/exhaust will also be necessary for a high power level. But you dont need the bottom rebuilt unless you already have high miles, or wish to push this car past about 6500rpm (which you can do with MR).
Stall converter, id use a Vigilante 2600-2800 stall.
