Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2002, 07:03 AM   #1
redwingvette
CF Senior Member
redwingvette's Avatar
Send a message via AIM to redwingvette
Default Heads revisited
Which would be the better choice.
Edelbrock Performer RPM- 64cc chamber 170cc runners- $941
Dart Iron Eagles 72cc chambers 180cc runners- $999
Dart Iron Eagles 72cc chambers 200cc runners- $899
Do I need new bolts for the Dart heads? I know I would need new bolts and washers to use the Edelbrocks.
redwingvette is offline   Reply With Quote
Old 11-08-2002, 02:01 PM   #2
69stingray
CF Senior Member
69stingray's Avatar
Default Re: Heads revisited (redwingvette)
May I suggest the "Corvette" heads. they have high velocity intake ports with an excellent intake/exhaust ratio. A great torque head for the street. The samll chamber also bump compression. I think LPE sells ported "Corvette" head with bigger valve for higher RPM power. these are the heads found on the ZZ4 crate motor. The edelbrock heads are similar. I think oyu can find them for $500-$600.
P/N: 12556463
http://www.johnbear.com/350sa.htm
[Modified by 69stingray, 12:05 PM 11/8/2002]
69stingray is offline   Reply With Quote
Reload this Page Heads revisited
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Duke and others/LT-1 cam revisited 327Heaven C1 & C2 Corvettes 14 08-26-2005 01:51 PM
dyno day dissapointment revisited KWIL C3 Tech/Performance 25 11-07-2003 01:50 PM
C6 Tire Information - Revisited......... TexasRedZ06 C6 Corvette General Discussion 13 06-30-2003 08:45 AM
Originality revisited SanDiegoPaul C3 Tech/Performance 41 12-17-2002 06:48 AM
The intake manifold question revisited Kevin Mason C3 Tech/Performance 23 05-17-2002 09:46 AM
Temps revisited...I say cooler is better jackdaroofer C4 Tech/Performance 41 01-08-2002 08:44 AM
siamesed tpi base revisited 88L98 C4 Tech/Performance 40 09-27-2001 02:08 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
