Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2002, 11:40 PM   #1
brimcc
CF Senior Member
brimcc's Avatar
Default fact or fiction - 400ci
I am thinking about putting a 400ci in my 79. I have heard that the 400 runs very hot. Should I stick with the 350? I am going to use 333882 heads. Thanks.
brimcc is offline   Reply With Quote
Old 11-08-2002, 12:40 AM   #2
Monty
CF Senior Member
Monty's Avatar
Default Re: fact or fiction - 400ci (brimcc)
Fiction....the only 400's that run hot are the one's that are built incorrectly. And you don't even need steam holes...
Please reconsider the use of 882 heads if you are intending on building a performance-oriented engine, you'll be severly handicapping yourself. There are plenty of affordable production heads that willl give you better performance than those lightweight, smog heads.
[Modified by Monty, 9:42 PM 11/7/2002]
Monty is offline   Reply With Quote
Old 11-08-2002, 03:51 AM   #3
1985z51
CF Senior Member
1985z51's Avatar
Send a message via AIM to 1985z51
Default Re: fact or fiction - 400ci (Monty)
definitely consider other heads.... :)
1985z51 is offline   Reply With Quote
Old 11-08-2002, 09:49 AM   #4
vader86
CF Senior Member
vader86's Avatar
vader86 is offline   Reply With Quote
Old 11-08-2002, 11:02 PM   #5
OatBoy
CF Senior Member
Default Re: fact or fiction - 400ci (vader86)
I dropped a 400 into my friends chevelle with a water pump and radiator we stole off of a wrecked suburban and the thing refuses to run over 150 degrees
OatBoy is offline   Reply With Quote
Old 11-09-2002, 12:23 AM   #6
CORKVETTE1
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
CORKVETTE1's Avatar
Default Re: fact or fiction - 400ci (1985z51)
I SECOND THAT :cheers:
CORKVETTE1 is offline   Reply With Quote
Old 11-12-2002, 10:17 PM   #7
69stingray
CF Senior Member
69stingray's Avatar
Per John Lingenfelter, "Performance wives tales have exaggerated the overheating problems associated with the 400's siamesed bores. This may have stemmed from hot rodders adding different heads and neglecting to drill the required steam holes between the center three cylinders. When a 400 block is properly machined and doesn't suffer from core-shifted thin cylinder walls, you can build an excellent torque thruster from a basic 400."
LPE also suggests pocket ported 441 heads with a cam of at least 230 duration @ 0.050" lift.
69stingray is offline   Reply With Quote
Old 11-13-2002, 09:00 PM   #8
sinistervette
CF Senior Member
sinistervette's Avatar
Default Re: fact or fiction - 400ci (CORKVETTE1)
Quote:
definitely consider other heads.... :) I SECOND THAT :cheers:
I'll third it! :D FICTION ON THE OVERHEAT PROBLEMS!
sinistervette is offline   Reply With Quote
Old 11-24-2002, 09:17 PM   #9
The Money Pit
CF Senior Member
The Money Pit's Avatar
Anyone that claims to be pulling 450-500 hp and is not having cooling issues is probobly not making the power they think. If you want to run 250-350hp out of a 400,the stock cooling system will most likely work out fine.
I had to run a Griffen 2 core aluminum radiator with a 16" Permicool fan to keep things under control.This is a fact!!!!!!!!!!!!!!!
The Money Pit is offline   Reply With Quote
Reload this Page fact or fiction - 400ci
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
