Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2002, 08:37 PM   #1
toy350
CF Senior Member
Default How Much Horsepower Can I Expect
I am rebuilding the engine in my midyear and was wondering how much horsepower this combination will make.
I a building a 383 stoker (350 bored .030) using 5.7 in rods with corvette 58cc aluminum heads (1.94/1.50). The compression ratio is expected to be 9.25:1 using Keith Black 28cc dished pistons. My camshaft is a mild roller with a lift of 471/480 and duration @ .050 of 219/227. The lobe separation is 112 degrees. The rocker arm ratio is 1.5:1.
Thanks. Also any suggestions to increase horsepower with the combination without affecting reliability, idle quality or streetability would be greatly appreciated.
toy350 is offline   Reply With Quote
Old 11-07-2002, 10:04 PM   #2
vader86
CF Senior Member
vader86's Avatar
Default Re: How Much Horsepower Can I Expect (toy350)
how big a carb?
vader86 is offline   Reply With Quote
Old 11-07-2002, 10:43 PM   #3
toy350
CF Senior Member
Default Re: How Much Horsepower Can I Expect (vader86)
Hey Vader86,
It has a standard TPI from a 1988 IROC Z with slightly larger than stock intake runners.
Old 11-08-2002, 02:06 AM   #4
vader86
CF Senior Member
vader86's Avatar
Ditch the TPI, seriously.
You would be making 420+ if you were using a Superram or something similar. But with a TPI system off a camaro, youll choke it to death, you wont make nearly enough power, and almost none after 4800rpm. You will have a crapload of torque however.
With the TPI, i would say between 350-375hp
Old 11-08-2002, 02:12 PM   #5
69stingray
CF Senior Member
69stingray's Avatar
Here is a good website for reference:
http://www.geocities.com/MotorCity/7610/dyno.htm
383 w/ Ported Vette heads and LPE cam similar duration, more lift) made close 440 HP.
I would bump the compression a little. The ZZ4 crate engine has those heads and a 10:1 compression. I haven't heard anyone complaining about street manners. the 10:1 should give you some higher numbers.
69stingray is offline   Reply With Quote
Old 11-08-2002, 04:00 PM   #6
bcwaller
CF Senior Member
bcwaller's Avatar
I get amazing torque running a Dyno2000 simulation. The run says over 500 TQ at 2000 RPM! HP peak is 345 HP at a measly 4500 RPM. This is damn good for a daily driver, but you likely leave a lot on the table if you want to run it hard.
I can't vouch for the accuracy of the similation either....
bcwaller is offline   Reply With Quote
Old 11-08-2002, 09:38 PM   #7
69stingray
CF Senior Member
69stingray's Avatar
Here is a 440 HP / 480 lb ft TQ 383 (via LPE).
383 w/ 5.565 rods
Ported Vette heads with 2.00/1.56 valves
LPE Cam (219/219 Duration @ 0.050 lift, 0.503/0.525 Valve Lift, 112 Lobe Separation)
Superram intake w/ 58mm throttle body
1.75 headers
NOTE: 362 lb.ft of TQ @ 1600 RPM! :D
You may also want to look at Edelbrock's Pro-Flo EFI. It can support 400+HP on a 355. No laptop needed!
http://www.edelbrock.com/automotive/mpfi_sbchevy.html
Reload this Page How Much Horsepower Can I Expect
Tags
c5, corvette, expect, horsepower, intake, iroc
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How much horsepower bbullard C6 Tech/Performance 14 09-07-2004 07:48 PM
How much can I expect to pay for DFI setup zelement C4 Tech/Performance 49 05-07-2004 09:51 AM
How much horsepower, how much money and how do I get into the 11's? Sparticus C5 Tech 16 09-07-2003 01:13 PM
Drag Racers.. What realistic decrease in ET can I expect from those mods? GrandSportC3 Drag Racing 19 08-23-2003 04:28 PM
How much horsepower can a M-20,21,22 handle? Adeotec C3 Tech/Performance 15 07-20-2003 03:05 PM
How Much H.P. Increase Can I Expect From Porting Intake & Heads? litevette C3 Tech/Performance 16 03-19-2003 08:05 PM
FLP headers package...any good? how much? where to get it... boblackhardtop C5 Tech 45 03-17-2002 11:36 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
