Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2002, 04:48 PM   #1
mnasrallah
CF Senior Member
mnasrallah's Avatar
Send a message via AIM to mnasrallah
Default Keeping your engine cool - this works
I installed a Ron Davis aluminum radiator w/ integral oil cooler several months ago and finally got to put it to the test on the track. WHAT A DIFFERENCE. Before, like allot of other posts I read, oil temps ranged from 250 to 275 degrees and I noticed a substantial loss of top end power as the temp. climbed. Now, the max all day was a cool 223 which resulted in gobs of power down the straights. For those experiencing similar problems, this is a way to go. There's no way you should subject any motor to those type of temps. There are several modifications and fittings you will need and this is setup is available thru several vendors. :cool:
On the drive down to Moroso at 120 mph that morning, oil was 150 degrees, water was 162 degrees ( with a 170 degree thermostat ) Even on those 95 degree days with air, the water and oil temp's rarely go above 200 degrees.
Track Conditions: Moroso Sunday Temps 80 - 89 degrees, relative humidity 95% Hot enough
mnasrallah is offline   Reply With Quote
Reload this Page Keeping your engine cool - this works
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Possible Fraud Caution savewave C3s for Sale/Wanted 134 02-05-2012 01:34 AM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
when is your fan clutch bad? ruby76 C3 General 14 06-09-2005 12:38 PM
C6 -- You wanted another "professional review" -- Missed Opportunities EHS C6 Corvette General Discussion 49 03-08-2005 06:51 PM
STS Remote Mounted Turbo systems Twin_Turbo C3 Tech/Performance 20 12-28-2004 04:44 PM
Help me solve my cooling problem Tony @ MPH C5 Tech 15 08-17-2004 12:36 PM
OK, I'm giving into the engine-pull gods, they must be really mad at me... mistaben C4 Tech/Performance 15 12-22-2003 02:12 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
