Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2002, 03:04 PM   #1
SRVFAN7
Junior Member
SRVFAN7's Avatar
Send a message via AIM to SRVFAN7
Default what is a safe compression?
I'm building a 350 motor and I have all my parts picked out... I'm wondering what my compression ratio is going to be. I've tried calculators, but they all give me different numbers from 9.1 all the way to 12.5. Anyone have a dependable formula? Can someone figure what it will be form this info...
4.030 bore
3.48" stroke
6" rods
11cc domes pistons
66cc heads
using a pretty lopey cam
we'll go with .039 gasket thickness
if any other numbers are needed just use a typical number for it. What ratio would be too high for a street strip car? I've read the archives and I'm fairly confused on what is good and what isn't. haha Any info would help! Thanks
Tony
SRVFAN7 is offline   Reply With Quote
Old 11-06-2002, 04:30 PM   #2
Ramanstud
CF Senior Member
Ramanstud's Avatar
Send a message via AIM to Ramanstud
Default Re: what is a safe compression? (SRVFAN7)
we'll also want to know iron vs aluminum.
From what I understand (I'm in the same situation) you can get away with 10:1 safely on a smooth-idle cam that doesnt bleed off a lot of compression, with aluminum heads. If you're all iron, drop that by one point (9:1). Some people will go higher depending on cam and experimentation (that last .5 ratio is variable I think, depending on gas quality and the specific characteristics of your motor), or they just like adding octane booster....
However, given the minimal HP gained by a half-point or so of compression on a daily driver... it's probably not worth the risk when you consider engine knock dangers and gas prices.
my $.02
Everyone else: feel free to correct me!
:cheers:
Ramanstud is offline   Reply With Quote
Old 11-06-2002, 04:44 PM   #3
SRVFAN7
Junior Member
SRVFAN7's Avatar
Default Re: what is a safe compression? (Ramanstud)
the heads are aluminum... anyone know approx. what compression ill have with these specs?
Old 11-06-2002, 05:28 PM   #4
vader86
CF Senior Member
vader86's Avatar
looks to be in the low 12s my figuring, too high for pump gas
vader86 is offline   Reply With Quote
Old 11-06-2002, 05:59 PM   #5
belair55
CF Senior Member
belair55's Avatar
Assuming zero deck height and .25 ring land height compression would be 12.407:1 way to high for pump gas.
with .020 deck height comp. would be 11.705:1 better but still high.
belair55 is offline   Reply With Quote
Old 11-06-2002, 06:16 PM   #6
Taijutsu
CF Senior Member
Why would you want a domed piston? A dome creates a slower burning combustion chamber. A flat piston would give you a better burn and lower CR. I run 10.25 w/o problems. I have a 218-224 cam, 6" rods, TFS heads, air gap and solid cooling system. I had zero problems even on 112 days w/air. I agree that conservative it best when in doubt.
Taijutsu is online now   Reply With Quote
Old 11-06-2002, 09:52 PM   #7
SRVFAN7
Junior Member
SRVFAN7's Avatar
Default Re: what is a safe compression? (Taijutsu)
Alright...I'm finally understanding some of these calculators and the numbers they are asking for... I also leanred some things about how neg and pos numbers work for a dome on a piston. I figure w/...
4.030 bore, 3.48 stroke, 6" rods, 67cc head, .02 gasket thickness
Ill have about a 10.0:1 The reason I was looking at domed pistons at 11cc was b/c it was in this package i was looking at and I didn't know...HA I did a lot of reading today and learned a lot..I'm a quick one! What you guys think of this combo anyways? Any suggestions on gasket thickness? Thanks!
Tony
Old 11-07-2002, 12:57 AM   #8
vader86
CF Senior Member
vader86's Avatar
If you would just change the pistons to something like dished or flat-top, you could do all of that. But 11cc domed pistons raises the CR too much.
Old 11-07-2002, 01:45 AM   #9
SRVFAN7
Junior Member
SRVFAN7's Avatar
Default Re: what is a safe compression? (vader86)
yea i forgot tomention that the 10:1 compression was with -5.4 dome pistons its all good i figured it out thanks guys
Reload this Page what is a safe compression?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What is your dynamic compression ratio? ramcharger C5 Forced Induction/Nitrous 11 12-25-2004 10:13 PM
Went to the Dyno on Saturday, a little disappointed HELP 96CollectorSport C4 Tech/Performance 14 03-30-2004 06:58 PM
What CR can you run on 91 pump gas? black_89_vette C4 Tech/Performance 11 01-10-2004 07:27 AM
Max safe compression ratio for street LT1? Jeff M C4 Tech/Performance 12 08-10-2003 03:45 AM
What is a safe compression ratio for an LT4 ??? 388 SOLid RoLLeR Engine Mods 18 01-01-2003 09:10 PM
What is the highest compression one can run on 93 octane & big cubes. Mopar Jimmy C5 Tech 9 10-20-2002 10:57 AM
What is most logical for what my new combo will have? scorp508 C4 Tech/Performance 40 10-03-2002 12:40 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
