Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2002, 06:58 PM   #1
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
Default Spend $$$ on Stroke 350 to 383 or P&P D-port heads
Opinions?
I guess I can always P&P the D-ports later. My builder says the HP/TQ improvement $$ are better spent on the stroke job! Make sense?
LD85 is offline   Reply With Quote
Old 11-05-2002, 07:55 PM   #2
69 N.O.X. RATT
CF Senior Member
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Spend $$$ on Stroke 350 to 383 or P&P D-port heads (ld85)
Need way more details,
69 N.O.X. RATT is offline   Reply With Quote
Old 11-07-2002, 07:26 AM   #3
gtsyellow
CF Senior Member
gtsyellow's Avatar
Send a message via AIM to gtsyellow
Default Re: Spend $$$ on Stroke 350 to 383 or P&P D-port heads (69 N.O.X. RATT)
why is it costing you more to build a 383? the crank is $50 more, the 6" rods are like $20 more than 5.7", the pistons sometimes cost more, i think the forged speed pros are still under $350. machine work is a little more, figure a couple hundred there, main studs are a must for setting up the windage try, plus they are stronger anyway. if you spend more than $500 total more for a 383 something isn't right.
gtsyellow is offline   Reply With Quote
Old 11-07-2002, 06:26 PM   #4
LD85
CF Senior Member
LD85's Avatar
Default Re: Spend $$$ on Stroke 350 to 383 or P&P D-port heads (gtsyellow)
Thats the info I was looking for. The builder says I am better off spending money on a 383 than spending $1000 on CNC porting the D-heads.
If the difference is that little in cost for stroking as opposed to going to a 355 then it only makes sense, to me, to stroke it and put larger valves on the Intake side with a new cam and intake. The D-ports stock are way better than my iron heads, they have to be with a valve job and lareger valves.
Thanks!
Reload this Page Spend $$$ on Stroke 350 to 383 or P&P D-port heads
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
