11-05-2002, 04:03 PM
CF Senior Member
Re: Will this work? (SRVFAN7)
Rod length has nothing to do with it. The piston design is what your worried about. Low end ($$) forged pistons like TRW 4 valve reliefs of questionable use need to be measured on any cam with excess of .550 lift especially with bigger than 2.02 valves. My JE pistons were out of the box ready to go with in excess of .700 lift with valves bigger than 2.10. I'm not familiar with 20 degree heads. Unless they have different valve placement I wouldn't worry, but I would check before firing the motor.
