Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2002, 10:33 AM   #1
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
Default 383 OWNERS , cast or steel who has what?
I know this is dependent on RPM and Money, whom has what cast or Steel?
Is steel an absolute necessity? I will not be turning more than 6000 RPM.
[Modified by ld85, 8:42 AM 11/5/2002]
LD85 is offline   Reply With Quote
Old 11-05-2002, 02:57 PM   #2
Lt1er
CF Senior Member
Lt1er's Avatar
Default Re: 383 OWNERS , cast or steel who has what? (ld85)
You can buy low end forgings from Scat or Eagle for much less than $500. either in 5140 or 4340 steel. From what I've seen and understand. Get the crank setup for internal balancing so you don't have to run a balancer and flywheel/flex plate as a matched set.
Lt1er is offline   Reply With Quote
Old 11-05-2002, 03:35 PM   #3
71roadster
CF Senior Member
71roadster's Avatar
Default Re: 383 OWNERS , cast or steel who has what? (Lt1er)
I am installing a Scat 9000 cast unit for the one piece seal block. It is supposed to be able to be internally balanced. I am having the machinist balance it when the rods and pistons arrive. I got the crank from flatlanderracing.com who drop shipped direct from scat. I paid only $200 for the crank. Everyone says these cranks are good to at least 6500 rpm and higher depending on the weight of the pistons and rods.
I remember seeing somewhere a comparison of strength between cast, the scat 9000 type cast, and forged. The 9000 series was just a little less strong then forged while the cast was a lot less strong then either.
Chris
[Modified by 71roadster, 10:36 AM 11/5/2002]
71roadster is offline   Reply With Quote
Old 11-05-2002, 07:50 PM   #4
74vetteman
CF Senior Member
Default Re: 383 OWNERS , cast or steel who has what? (71roadster)
From what I've read, this is the order of strength, from weakest to strongest
-Factory cast iron
-Scat cast steel and factory forged 1053 are about equal, with a new factory forged maybe a little stronger
-4340 is strongest
There are some other alloys out there, but these are the most common. There is some debate whether 4340 non-twist forging, or 4340 billet is stronger.
74vetteman is offline   Reply With Quote
Old 11-07-2002, 07:23 AM   #5
gtsyellow
CF Senior Member
gtsyellow's Avatar
Send a message via AIM to gtsyellow
Default Re: 383 OWNERS , cast or steel who has what? (74vetteman)
a few very very VERY bright engine builders have told me the scat 9000, cast steel crank can live at 800hp in a drag racing enviroment quite well. so far neither have seen one break on a SBC. i personally spin mine to 6900rpms & have never had one slight issue. i'm fairly confident this crank could spin 7500rpms & not have issues. internal balance is a must but they make it easy. now everyone kick me for not buying the 383 crank for $50 more. :lol:
gtsyellow is offline   Reply With Quote
Old 11-07-2002, 06:29 PM   #6
LD85
CF Senior Member
LD85's Avatar
Default Re: 383 OWNERS , cast or steel who has what? (gtsyellow)
I agree, I saw some rally good Scat 9000 prices at Flatlander.
Looks like a stroker is in the cards.
All I am looking for a real low 13's or high 12's car !
Old 11-10-2002, 10:16 PM   #7
Neil350
CF Senior Member
Send a message via AIM to Neil350
I used a 385 stroker kit from Performance Automovtive Warehouse, The kit came complete balanced with forged pistons, custom grd crank, piston rings, balanced, with crome moly rod bearing for about $650.....I'm running about mid twelves. On pepboys tires! If you wanna know what else I got send me a PM, or drop me an email!
Neil350 is offline   Reply With Quote
Old 11-16-2002, 09:20 AM   #8
madvette74
CF Senior Member
madvette74's Avatar
what about nodular iron??? stonger than cast..
madvette74 is offline   Reply With Quote
Old 11-16-2002, 11:52 AM   #9
LD85
CF Senior Member
LD85's Avatar
Default Re: 383 OWNERS , cast or steel who has what? (madvette74)
Sorry dudes, my plans have changed. I am now building a 406 but this info is still helpful!
Reload this Page 383 OWNERS , cast or steel who has what?
Tags
383, cast, crankshaft, steel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
