Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-05-2002, 06:50 AM   #1
vettef6
CF Senior Member
vettef6's Avatar
Default need 4" stroke one piece seal crank
I have a 1992 LT1 and I'm building a 408ci engine and want to use a 4.0" crank with 5.850" rods. Is there anybody out there that knows who sells a one piece seal 4.0" crank so I can use my 5.850" rods. I know that Eagle makes one but I have to use 6.0" rods.
Any ideas
vettef6 is offline   Reply With Quote
Old 11-05-2002, 03:18 PM   #2
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Default Re: need 4" stroke one piece seal crank (vettef6)
Callies should make one.
http://www.callies.com
SPD DMN is offline   Reply With Quote
Old 11-06-2002, 05:59 AM   #3
vettef6
CF Senior Member
vettef6's Avatar
Is there nobody else out there that really knows who builds this crank!!
Do not guess, I have to know for sure.
Old 11-06-2002, 07:34 AM   #4
Twin_Turbo
CF Senior Member
Try hank the crank, they can make one for you
Marck
Twin_Turbo is offline   Reply With Quote
Old 11-06-2002, 08:02 AM   #5
vettef6
CF Senior Member
vettef6's Avatar
Default Re: need 4" stroke one piece seal crank (Twin_Turbo)
do you have his link or address?
thanks
Old 11-06-2002, 09:01 AM   #6
yedister
CF Senior Member
http://www.hankthecrank.com/
yedi
yedister is offline   Reply With Quote
Old 11-06-2002, 12:17 PM   #7
SPD DMN
CF Senior Member
Cruise-In I Veteran
SPD DMN's Avatar
Default Re: need 4" stroke one piece seal crank (yedister)
Do you have a phone? Callies manufacturs all kinds of cranks including custom built ones. They can make just about anything so I was not guessing. Now whether it is in your price range you are looking for is another story.
Old 11-07-2002, 12:02 AM   #8
AKS Racing
CF Senior Member
AKS Racing's Avatar
Several manufacturers make the crask. Cola made mine. Callies does not, except custom, which was like $3,200. Most all of these are made for a 6" rod. You can buy a 6" rod crank and have it cut down for the 5.85" rod. Either way it is going to take some Mallory metal to balance. You will require a 5.85" rod if you want the rings down for N2O, or for SC applications. I do not think you are going to get there with Eagle rods in a stock block. You will hit water! You need to run something like the Oliver stroker billet.
I have built several stock block, 4.00" stroke engines now, and they seem to work well. I currently am putting together a 4.125" stroke with a 400 aftermarket block. The 4 1/8" stroke justs gets too out of wack in relation to ring stack and rod ratio in force fed applications.
Hope this works for you.
Aaron
AKS Racing is offline   Reply With Quote
Old 11-07-2002, 09:02 AM   #9
vettef6
CF Senior Member
vettef6's Avatar
Default Re: need 4" stroke one piece seal crank (AKS Racing)
Please correct me if I’m wrong. I will have to take 5.850” I-beam rods instead of an H-beam because this rod does not need so much clearance work. I was also told that the Scat I-beam rod is very similar to the Oliver, in both weight and design. Who has more detailed info?
Reload this Page need 4" stroke one piece seal crank
Tags
1piece, 40, 400, crank, hank, seal, stroke
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
GM announcement on LS7 & other engine stuff Troy Roberts C6 Z06 Discussion 131 09-12-2004 12:23 AM
Few questions bout 383 and 396 engines SaltyNuts Engine Mods 20 10-17-2003 10:30 PM
Gen V block.... What heads will work? compuvette Engine Mods 10 04-15-2002 01:10 AM
What can be done to an L98 block? scorp508 Engine Mods 12 02-16-2002 11:19 AM
Merlin II vs. Dart Big 'M' block Flareside Engine Mods 21 12-22-2001 06:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
