Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-30-2002, 06:44 PM   #1
cardo0
CF Senior Member
cardo0's Avatar
Location: So Cal- - Defend your ideas with facts. Not personal attacks.
Default Dish volume of goodwrench piston #12361371??
Can't find the specified dish volume for my goodwrench 350 piston (gm #12361371). Tried to measure piston volume + crevice volume + deck hieght volume with block in car but failed. Plexiglas kept leaking when about 9/10ths full (~22cc). Burned a day trying but finally bolted head on. Called everyone that would answer the phone at GM but still no info that I trust. [IMG][/IMG]
How can you post pictures allong with disscusion text as I have image of piston ready?
cardo0 is offline   Reply With Quote
Old 10-30-2002, 08:11 PM   #2
Twin_Turbo
CF Senior Member
Default Re: Dish volume of goodwrench piston #12361371?? (cardo0)
posting the pic:
[img]http://www.yourprovider.com/yourserverspace/yourpicture.jpg[/img]
That's the piston you mean.
This piston is cast aluminium, for 350-300 and 330 HP service with SP I.D. This 350 standard, pressed pin, high performance piston has a 9.1:1 compression ratio with 64cc head chamber volume (ID#10046106, 14075651 or 14093679
Can't find anything on the dish volume.
Marck
[Modified by Twin_Turbo, 5:11 PM 10/30/2002]
Twin_Turbo is offline   Reply With Quote
Old 10-30-2002, 09:31 PM   #3
Taijutsu
CF Senior Member
Don't forget the piston to head clearance "quench". GM factory engines are usually .025 in the hole. A total of .040 is optimum. The better the quench, the more CR possible.
Taijutsu is offline   Reply With Quote
Old 10-30-2002, 10:30 PM   #4
Twin_Turbo
CF Senior Member
Default Re: Dish volume of goodwrench piston #12361371?? (Taijutsu)
decking to 9.000 for a FelPro .38 gasket or 9.010 for a steel shim is reasonable. 0.38" is a good quench height,
Old 11-11-2002, 03:56 AM   #5
jackson
CF Senior Member
Can't help you with that GM # ... BUT ... here's specs (w/76cc heads) on four Speed-Pro cast replacement types that might help you get close:
(1) pn 345: Flat, dome vol = -5cc, 4 VR's, CD = 1.560", CR = 8.24:1
(2) pn 423: Dished, dome vol = -10cc, 4 VR's, CD = 1.540", CR = 7.89:1
(3) pn 620: Dished, dome vol = -22cc, 4 VR's, CD = 1.540", CR = 7.23:1
(4) pn 670: Dished, dome vol = -11cc, 4 VR's, CD = 1.560", CR = 8.08:1
[Modified by jackson, 2:21 AM 11/11/2002]
jackson is offline   Reply With Quote
Reload this Page Dish volume of goodwrench piston #12361371??
Tags
10046106, 12361371, 350, aluminum, cast, casting, compression, dish, gm, goodwrench, height, pisto, piston, pistons, specs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
