LT-4 heads flow well enough for s/c
I have the Hot Cam and did gasket matching, bowl clean up and polishing, three angle valve job. What my concers are, If i install a supercharger would it make worth while hp gains through those heads. I was planning on using the stock crank and getting new rods and lower comp pistons, but keeping the stock 350ci displacement for now. Love the looks and punch a s/c gives, the budget will be lower than I'd like ....but hey that's life.
:cheers: :cheers:
:cheers: :cheers:
Re: LT-4 heads flow well enough for s/c (1CanuckVette)
You should use a forged crank as well, you dont want one weak link to break and cuase damage to the other parts of your engine.
