About moth ball in the gaz
Depending upon the chemical composition of the moth *****, the napathene released into the gas will raise the octane level a few decimal points. Whether or not that translates into more power depends upon the engine, i.e., if the engine is designed to run on 87 octane, 87.5 octane isn't going to make much of a difference in HP output.
