Engine Swap
Engine Swap
Hello, I looked around and I think this is the nearest topic that relates to my question, even if just a little bit.
But I'm trying to restore a 1966 Chevy Caprice, but instead of finding a 350, I want to drop a good ol' Vette engine in. The problem is, I've never made a toy car like this, and I'm not sure about part of the car I'll need to change to deal with this new engine.
One of the things I've run into, for example, is the ECU, you're supposed to get it programmed with the VIN, but I'm trying to put it in a Caprice, so will that cause a problem? Any help or suggestions is much appreciated, thank you much.
