HP Tuners/Injector Dynamics
Old 05-11-2013, 11:48 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default HP Tuners/Injector Dynamics
Injector Dynamics fuel injectors are the result of batch testing large quantities of specially modified fuel injectors, and then carefully matching them into sets based on their dynamic flow across the pulsewidth range. The result is vastly superior cylinder to cylinder consistency, even at very low pulsewidths.
In addition to receiving tightly matched injectors, you will be provided with dead time compensation values across the entire pressure and voltage range of the injector. This data will insure that the compensations in your ECU work properly, and your air fuel ratios will remain consistent as atmospheric or voltage conditions change.
05-13 CHEVROLET CORVETTE/CAMARO/CADILLAC/PONTIAC ALL GM LS3, LS7, L76, L92, and L99 850cc Injector; 15mm Top; Orange Lower O-Ring; Set of 8; No PnP Adapter Required
http://www.xplosiveperformance.com/0...ed_p_3416.html
05-13 CHEVROLET CORVETTE/CAMARO/CADILLAC/PONTIAC ALL GM LS3, LS7, L76, L92, and L99 725cc Injector; 15mm Top; Orange Lower O-Ring; Set of 8; No PnP Adapter Required; Requires 14mm Fuel Rail Spacer
http://www.xplosiveperformance.com/0...er_p_3417.html#
05-13 CHEVROLET CORVETTE/CAMARO/CADILLAC/PONTIAC ALL GM LS3, LS7, L76, L92, and L99 1000cc Injector; ID1000 Injector; 15mm Top; Orange Lower O-Ring; Set of 8; No PnP Adapter Required; Requires 14mm Fuel Rail Spacer
http://www.xplosiveperformance.com/0...er_p_3418.html
14mm adaptor top for Injector Dynamics injectors
http://www.xplosiveperformance.com/1...s-_p_3421.html
HP Tuner, VCM Suite with MPVI Standard and GM Credits, Kit
http://www.xplosiveperformance.com/H...t-_p_3378.html
HP Tuner, VCM Suite with MPVI Pro and GM Credits, Kit
http://www.xplosiveperformance.com/H...it_p_3377.html#
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
XPMOTORSPORTS ON FACEBOOK
Old 05-18-2013, 08:29 AM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
Old 05-21-2013, 04:29 PM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
Old 05-23-2013, 07:59 AM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
Old 08-21-2013, 08:37 AM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
Old 09-01-2013, 07:26 PM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
Old 09-01-2013, 07:27 PM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
Old 09-04-2013, 08:35 AM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
Old 09-10-2013, 09:05 AM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
Old 09-14-2013, 09:10 AM
Former Vendor
St. Jude Donor '13
Call 888.493.8041
PM
Free Shipping
use IDFS
at checkout
Follow
To HP Tuners/Injector Dynamics
Quick Reply: HP Tuners/Injector Dynamics
