Check our version of the Big 3!
Supporting Vendor
Hi Everyone!
We have put together a Big 3 kit for you that is easy to install!
With all of the high-tech electronics that have been incorporated into your C5 Corvette, not to mention additional after market electronics and stereo systems, it can take a toll on the factory charging systems ability to keep up. Especially if, over time, connections have become corroded.
Installing a BIG 3 upgrade can be very beneficial as many on the Corvette forum will tell you. SacCityCorvette has developed a BIG 3 installation kit for the C5 Corvette. It is made from all high quality materials and designed so it will not look like an aftermarket universal kit. For safety it has a 100 amp heavy duty fuse, uses automotive grade 4 gauge wire, (not the type most car stereo shops use), the positive wire has a mesh sleeve over it for additional protection, all connections are hydraulically crimped and come with all the hardware needed to do the install. The installation takes about thirty minutes with simple hand tools. If you have doubt that this BIG 3 kit will make any difference in your charging system, please check out our test video below and see how the voltage increases when we connect it! Update: If you have an issue with your lights dimming when you turn on other power accessories, several people have reported that our Big 3 has fixed that.
Here is the link with all the info. http://www.saccitycorvette.com/Big-3.html
Side terminal $119.95 Top Post $139.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
Supporting Vendor
Our Vette just seemed like it ran better with the Big 3 installed.
Could be in our heads or could be the that the extra voltage
really helped. Just saying!
Supporting Vendor
This is a great add on for you that have after market stereo systems
Supporting Vendor
These Big 3 upgrades do make a difference. Just ask the owners that put them on their Vettes.
Supporting Vendor
Supporting Vendor
Get your Vette ready for summer! The Big 3 helps when running A/C, Stereo and lights all at the same time.
Supporting Vendor
The c5 Big 3 will not be clean fit on a C6. We have a C6 prototype but
the C6 we were testing on got sold. So we haven't had a C6 to test fit our prototype on. But we are looking for one.
Christian
Supporting Vendor
Great upgrade for people with after market radios!!!
Supporting Vendor
