Check our version of the Big 3!
Old 01-04-2013, 01:23 AM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Check our version of the Big 3!
Hi Everyone!
We have put together a Big 3 kit for you that is easy to install!
With all of the high-tech electronics that have been incorporated into your C5 Corvette, not to mention additional after market electronics and stereo systems, it can take a toll on the factory charging systems ability to keep up. Especially if, over time, connections have become corroded.
Installing a BIG 3 upgrade can be very beneficial as many on the Corvette forum will tell you. SacCityCorvette has developed a BIG 3 installation kit for the C5 Corvette. It is made from all high quality materials and designed so it will not look like an aftermarket universal kit. For safety it has a 100 amp heavy duty fuse, uses automotive grade 4 gauge wire, (not the type most car stereo shops use), the positive wire has a mesh sleeve over it for additional protection, all connections are hydraulically crimped and come with all the hardware needed to do the install. The installation takes about thirty minutes with simple hand tools. If you have doubt that this BIG 3 kit will make any difference in your charging system, please check out our test video below and see how the voltage increases when we connect it! Update: If you have an issue with your lights dimming when you turn on other power accessories, several people have reported that our Big 3 has fixed that.
Here is the link with all the info. http://www.saccitycorvette.com/Big-3.html
Side terminal $119.95 Top Post $139.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 02-20-2013, 02:44 PM
SacCityCorvette
Supporting Vendor
Top post battery mount available!
Old 03-29-2013, 12:29 PM
SacCityCorvette
Supporting Vendor
Improves electrical efficiency!
Old 05-17-2013, 02:05 PM
SacCityCorvette
Supporting Vendor
Old 07-08-2013, 07:40 PM
SacCityCorvette
Supporting Vendor
Our Vette just seemed like it ran better with the Big 3 installed.
Could be in our heads or could be the that the extra voltage
really helped. Just saying!
Old 07-25-2013, 02:58 PM
SacCityCorvette
Supporting Vendor
The Big helps keep the electrical system reliable!
Old 08-07-2013, 06:57 PM
SacCityCorvette
Supporting Vendor
This is a great add on for you that have after market stereo systems
Old 09-25-2013, 06:52 PM
SacCityCorvette
Supporting Vendor
Nice electrical upgrade!
Old 10-17-2013, 12:50 PM
SacCityCorvette
Supporting Vendor
These Big 3 upgrades do make a difference. Just ask the owners that put them on their Vettes.
Old 12-04-2013, 07:35 PM
SacCityCorvette
Supporting Vendor
Big 3's for C6 coming soon!
Old 03-16-2014, 10:26 PM
rowdymax
rowdymax's Avatar
Where is the C6 version of the Big 3??? Interested...
Old 03-18-2014, 05:48 PM
SacCityCorvette
Supporting Vendor
Hi rowdymax,
We are hoping to have them ready in the next couple weeks.
Thanks,
Christian
Old 04-28-2014, 06:26 PM
SacCityCorvette
Supporting Vendor
Get your Vette ready for summer! The Big 3 helps when running A/C, Stereo and lights all at the same time.
Old 04-29-2014, 11:13 PM
Paukert
Cruising
Paukert's Avatar
Very nice.
Old 05-09-2014, 01:47 PM
SacCityCorvette
Supporting Vendor
Thank you Paukert!
Old 05-28-2014, 09:13 AM
Guru_4_hire
Guru_4_hire's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
It will fit a C6 if you swap in a C5 battery which reverses the pole order.
Barely though.
Old 05-28-2014, 07:12 PM
SacCityCorvette
Supporting Vendor
Barely though.
Hi Guru,
The c5 Big 3 will not be clean fit on a C6. We have a C6 prototype but
the C6 we were testing on got sold. So we haven't had a C6 to test fit our prototype on. But we are looking for one.
Christian
To Check our version of the Big 3!
Old 08-05-2014, 01:00 PM
SacCityCorvette
Supporting Vendor
Great upgrade for people with after market radios!!!
Old 09-09-2014, 12:14 AM
SacCityCorvette
Supporting Vendor
Old 11-06-2014, 12:15 PM
SacCityCorvette
Supporting Vendor
We have the Big 3 in stock.Same day shipping!!!!!
Quick Reply: Check our version of the Big 3!
