409hp @ 6k rpm and 427lb ft of torque @ 3500rpm?
Old 09-09-2012, 09:51 PM
SPC Meyer
SPC Meyer's Avatar
Default 409hp @ 6k rpm and 427lb ft of torque @ 3500rpm?
I was thinking of tryin to build an engine using these specs,
this is out of Ryans engine combination and bible site.
(Combos 93 to 100)
http://www.ryanscarpage.50megs.com/combos13.html
Displacement: 350 cu. in.
Carburetor: Holley 750 double-pumper
Heads: GM L31 Vortecs, pocket-ported, with 1.94/1.50 in. valves
Intake: Edelbrock Performer RPM Vortec
Camshaft: Comp Cams Xtreme Energy 268 hydraulic, with
0.478/0.480 in. of lift and 224/230° of duration @ 0.050 in. of lift.
Exhaust: Hedman 1 5/8 in. headers
Distributor: HEI
Comp. Ratio: 9.4:1
MAX HP: 409 @ 6000
MAX Torque: 427 @ 3500
The vette I have is a 78 with a 3.08 rear and freshly rebuilt TH350 with original stall torque converter.
My question is, how would an engine act that reaches its peak torque way before max HP is reached. I chose it cause it looks cheap to build "non roller cam". What would be a good stall speed and rear end gear. Thanks
Old 09-12-2012, 10:19 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
24-2600 stall
3.50-3.70 gear
700r would be really fun with the lower first gear, would pull OD just fine on the hwy
Wouldnt sweat where torque/hp peaks are on this one
With an AFR 180 head that combo would really tear it up on the street!!
Old 09-13-2012, 10:31 PM
danno85
danno85's Avatar
That makes it way fun to drive...
To 409hp @ 6k rpm and 427lb ft of torque @ 3500rpm?
Quick Reply: 409hp @ 6k rpm and 427lb ft of torque @ 3500rpm?
