Small vs Big Block?
Old 01-25-2012, 07:08 PM
jost6453
Support Corvetteforum!
jost6453's Avatar
Default Small vs Big Block?
What's the techincal diff between a 'small block' vs 'big block' engine? I was asked by some buddies but didn't have a great answer, other than physical size. Is the C6 Z06 a 427 small block?
Old 01-25-2012, 08:37 PM
toddalin
toddalin's Avatar
Received 1,167 Likes on 486 Posts
Typically, as in the case of the Chevys, Fords, and Chryslers, it's based on the bore spacing. But that doesn't apply to all makes. For example Pontiac used the same block for the 326 to the (IIRC) 455 CI engines.
Old 02-09-2012, 02:19 PM
cwis9992
cwis9992's Avatar
i believe journal size is involved as well. im not exactly 100% on that but im pretty sure of it
Old 02-24-2012, 01:17 AM
cardo0
cardo0's Avatar
Location: Las Vegas - Just stop perpetuating myths please.
That's a very good answer.
If you look in the GMPP catalog they have all their small and big blocks listed by part numbers in their own respective section so it makes fairly easy. But the LSX motors have no big or small block labels - only LSX blocks whether 260 or 427 cubes.
U can stroke and bore a small block to well over 400 c.i. but it is still a small block regardless. Only the marketing employees at GM know why they call anything what they do.
cardo0
Old 02-26-2012, 12:14 PM
Ben Lurkin
Ben Lurkin's Avatar
St. Jude Donor '09
The big block chevy is physically and dimentially a much larger engine than the small block. Take a look at them side by side and there's no question which is which and why. The BBC can be had in sizes over 700 cubic inches.
The lsx series is the third & fourth generation of the small block chevy. As mentioned above, they share the same 4.40" bore spacing.
Old 02-26-2012, 12:55 PM
RobRace10
RobRace10's Avatar
Guess which one is the 427 and which is the 350.
Old 03-20-2012, 03:22 PM
NateReyes1986
5th Gear
NateReyes1986's Avatar
Nice, I'm a visual person so the side-by-side is definitely working for me.
Old 03-20-2012, 04:16 PM
toddalin
toddalin's Avatar
Actually, from this perspective, the reason that the big block looks big is not the block at all, but the splayed valve heads used on Chevy big blocks as opposed to the in-line valves used on Chevy small blocks.
If you were to look at a 4-valve small block, or even a splayed or opposing valve head such as a Ford Cleveland of Chrysler hemi, you would be hard pressed to see this difference from this angle.
Old 05-22-2012, 11:25 AM
RobbSalzmann
RobbSalzmann's Avatar
St. Jude Donor '12
Nice pic!
FWIW, my 427 looks just like the one on the left.
Old 07-06-2012, 10:55 AM
Don 79 TA
Don 79 TA's Avatar
one of the old tricks i was taught from the engine shops back in the day was valve cover bolts, meaing BBC had more then the SBC
how this "theory" applied to other makes.... dunno
of course this was back in the early 80s when i heard this, quiet honestly heard it referenced like that alot too
since i'm a pontiac fan, you can always tell a non-pontiac person makes an add when they describe a pontiac motor as a Big Block
sure it's big in size, but basically dimensionally all the same so technically there was no small or big block pontiac
from what i remember, it was used in reference to it's CI's
meaning most small block motors were typically 350's and under, over used to be classified as big
however you can now get 450+ cubes in a small block dimensions, so again kindda throws that out
Old 08-07-2012, 03:30 PM
jasper711
jasper711's Avatar
The terms "big block" and "small block" are predominately in reference to classic Chevy's. There are also large and small classic Mopars. There is no big block or small block Pontiac as they all share external dimensions, the definition gets murky with Olds and Buick as it becomes a matter of deck height, and Ford really muddied the water with old Y blocks, the small block, FE's (which are sort of smallish by big block standards, but generally referred to as big block), MEL's (the biggest block available when FE's were made), Cleveland family (which I've heard rednecks refer to as "big block 351's") and then the largest 385 series; none compatible with each other.
All of these designations are somewhat obsolete on new cars and in any case the designation is no better than the person speaking it. But a big block Chevy will always be 396-402-427-454 etc., and a small block Chevy is usually 265-283-302-305-307-327-350-400
Old 08-08-2012, 02:46 PM
randyredleg
randyredleg's Avatar
To really confuse things,the 348 was a big block (also used for a 409/427)
Old 08-13-2012, 11:26 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
So was the 366
Old 08-29-2012, 09:26 PM
ManiM1191
ManiM1191's Avatar
awesome thread! great explanations and pic on here! thanks!
To Small vs Big Block?
Quick Reply: Small vs Big Block?
